205 1.9.gti starting prob...again
thrappit
Unread post by thrappit »
Sorry to bore you with this chaps, not yet got a new battery will get that tomorrow, i put the battery on charge today and the charger was reading that it pretty much fully charged, now when i put this on the car none of the electrics that draw power want to work and the symptoms point towards a flat battery, surely this is the case, is there anything else that could show the results the im having [:0] as you can probably guess i lknow NOTHING about cars and you guys are my saviors cheers again!!
JohnD
(Donor 2022)
x 72
Unread post by JohnD »
It still looks as though you have a duff battery. It's so duff that it won't accept a charge. If the car starts readily on a jump start, there can't be much wrong with anything else. When you get the new battery on it, check that the output of the alternator is correct.
thrappit
Cheers john, thanks for your advice, i will keep in touch and let you know the outcome, been a great help [:D]
thrappit
Changed the battery, everything is fine now thanks, apreciate the advice given
JohnD
(Donor 2022)
x 72
Well done - I hope you'll act on the last bit of advice. Get the alternator to battery output checked. If it's over-charging, it could be why your battery got b*******.
