205 1.9.gti starting prob...again
Post Reply
thrappit
My Cars:
Post by thrappit »
Sorry to bore you with this chaps, not yet got a new battery will get that tomorrow, i put the battery on charge today and the charger was reading that it pretty much fully charged, now when i put this on the car none of the electrics that draw power want to work and the symptoms point towards a flat battery, surely this is the case, is there anything else that could show the results the im having [:0] as you can probably guess i lknow NOTHING about cars and you guys are my saviors cheers again!!
JohnD
(Donor 2022)
My Cars: 2010 Citroen C5-X7 tourer
1998 Citroen Saxo 1.5D
2018 Citroen C4-B7
1998 Peugeot 306. 1.9D
2011 Citroen C1
x 72
Contact:
Post by JohnD »
It still looks as though you have a duff battery. It's so duff that it won't accept a charge. If the car starts readily on a jump start, there can't be much wrong with anything else. When you get the new battery on it, check that the output of the alternator is correct.
thrappit
My Cars:
Post by thrappit »
Cheers john, thanks for your advice, i will keep in touch and let you know the outcome, been a great help [:D]
thrappit
My Cars:
Post by thrappit »
Changed the battery, everything is fine now thanks, apreciate the advice given
JohnD
(Donor 2022)
2018 Citroen C4-B7
2011 Citroen C1
x 72
Contact:
Post by JohnD »
Well done - I hope you'll act on the last bit of advice. Get the alternator to battery output checked. If it's over-charging, it could be why your battery got b*******.
Post Reply
