Activa Radiator Top Hose O-Ring
DHallworth
x 167
Unread post by DHallworth »
My Activa has been sitting in the shed for the last 6 months or so and has done no mileage in the last couple of years.
When I started the car on Sunday evening to give her a check over before her annual MOT I noticed that the car was loosing coolant quickly from the top hose connection into the radiator.
My radiator has a bayonet type fitting where you push the hose into the radiator and put a metal clip over the top of it.
I took it apart, cleaned it etc but it made no difference.
Rang Citroen to purchase the O-ring but was told it was only available with the top hose at a cost of £170.00.
I rang our local Peugeot dealer who I use for all my MOT's etc and he told me he had an O-ring on the shelf and to go and get it.
I took a run down, handed over 65p and left with an O-ring that looked identical. It's a shaped O-ring so one out of my box of generic ones wouldn't do unfortunately.
Tried it this morning and it's a perfect fit and has cured my leak.
I'm not sure what it was but I'm going to get the part number incase anybody else has the same problem.
Just thought I'd post this incase someone else has the same problem and resorts to buying a hose as this is a damn site cheaper!
David.
'98 Xantia Activa V6 :-D
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
Toby_HDi
x 3
Unread post by Toby_HDi »
Its always worth consulting Peugeot for Citroen parts and vice versa, especially in these circumstances.
Part numbers are invariably the same.
Toby
Previous:
2004 Peugeot 407 HDi 138 SE Luxury Pack
2001 S2 Xantia HDi 110 SX
2001 Peugeot 406 V6 Coupé
1998 S2 Xantia Activa
2000 S2 Xantia HDi 110 SX
1999 Peugeot 406 2.0 16v Estate
robert_e_smart
x 14
Unread post by robert_e_smart »
Thats a great find David. I imagine the same part can be used in 2.1 TDs as well as the same engined Xms.
1990 XM 2.1 Turbo SD
1991 BX 16 TGS Auto
1992 ZX 1.6 Aura Auto
1994 Xantia 2.0 16V VSX
2008 C5 2.7 Exclusive
DHallworth
x 167
As promised...
Part Number: 1343Z4.
This O-ring fits perfectly onto the top hose of the Activa with the bayonet fitting on the top hose.
Citroen don't sell them seperately.
Cost me 65p yesterday.
David.
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
davetherave
x 4
Unread post by davetherave »
Is this the same o ring as on the 2.1td later rad as mine has a massive leak!
65p would be a cheap fix!
(95) XM Silver 2.1td Exclusive.
(87) Cx 2.5 DTR T1 undergoing major cosmetic surgery.
GPZ500s
x 8353
Yes it is Dave. Activa and the 2.1TD share the same rad. Also shared by late 1.9TDs as well...
Excellent tip about the Peugeot O ring being good David :D
davetherave
x 4
:D
Cheers! ill be buying on tomorow!
GPZ500s
DHallworth
x 167
My dealer could only get me them in packs of 10 so if you need one let me know.
David.
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
