lexia 3 diagnostics
crazylegs
lexia 3 diagnostics
Unread post by crazylegs »
does anyone know where i can get one at a reasonable price? does anyone have one they would lend or hire out?
dead berlingo 57 plate to investigate so if someone near SN9 who could plug in and have a look would be great.
x 8468
In what way is it dead?
crazylegs
no fuel. it just stopped. a local garage with limited diagnostics and the aa confirm it as a fuel supply problem.
MikeT
x 232
Re: lexia 3 diagnostics
Unread post by MikeT »
crazylegs wrote:does anyone know where i can get one at a reasonable price? does anyone have one they would lend or hire out? .
Check the Lexia map (think it's in the sticky section) to see who's nearest you. They can be had cheap but you need a laptop as well.
crazylegs
thanks mike t . i have contacted my nearest member but no reply yet.
a bit of an update, it seems that there is no lift pump as there is a bulb to prime the fuel pump. i have checked all the connectors done a service and pumped the bulb till its hard. you can here the bubbles in the tank so the pipes not blocked so its a sensor of some sort. i think !!!
anyone got any ideas whats most likely ?
