does anyone know where i can get one at a reasonable price? does anyone have one they would lend or hire out?
dead berlingo 57 plate to investigate so if someone near SN9 who could plug in and have a look would be great.
lexia 3 diagnostics
- x 8325
crazylegs
MikeT
- x 232
Re: lexia 3 diagnostics
Check the Lexia map (think it's in the sticky section) to see who's nearest you. They can be had cheap but you need a laptop as well.crazylegs wrote:does anyone know where i can get one at a reasonable price? does anyone have one they would lend or hire out? .
crazylegs
thanks mike t . i have contacted my nearest member but no reply yet.
a bit of an update, it seems that there is no lift pump as there is a bulb to prime the fuel pump. i have checked all the connectors done a service and pumped the bulb till its hard. you can here the bubbles in the tank so the pipes not blocked so its a sensor of some sort. i think !!!
anyone got any ideas whats most likely ?
