Just had a friend do an aircon check on my Xantia prior to a re-gas.
The machine announced a leak was discovered so we couldn't complete the job. Despite using a leak detector light and special glasses we couldn't locate the leak.
Are there any common leak area's on X 2's ?
Aircon leaks ?
Aircon leaks ?
Now using '00 Xantia LX HDI, pov spec
My past Citroens :-
'00 Xantia SX HDI, now dead due to accident
'99 Xantia HDI 110 Exclusive, RIP
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
'79 CX2400 Pallas (scrapped )
& a couple of Peugeots !
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
- VertVega
- x 13
Each time I have air condition serviced, they add a colored fluorescence dye detectable under the ultraviolet light.
It has green/yellow color and even visible by plain eye.
- Once it had visible traces coming down, on the side of the condensor where the pipes are connected.
Pipe and condensor connection probably developed hair cracks.
- Second place was the filling valves. One of them leaked.
- My Cars: M reg Xm S2 2.1td Auto Exclusive. 269k and rising
L reg XM S1 V6 12v Manual SEi
L 94 XM 2.1 TD auto total resto
2008 Peugeot 207 Sw 1.6 16v hdi. 217k and rising
2010 Peugeot 207 SW 1.6 8v HDi 161k and rising - x 71
Compressor bodies are common..
If it has the split type body were one half is fitting over the other the seal in that half can and does leak... noticeable by compresssor oil seepage or evedance of gas leakage.
Other then that oint seals, or rubber hose parts..
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
That could be a good prospect for the problem on mine then !! The high pressure outlet on the hydraulic pump has blown about 10 times in the past !!!
Thanks guys, gives me a few area's to examine.
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
