Thermostat
wulfgar2k
Thermostat
Unread post by wulfgar2k »
Hi
went out in the car( 306 1.6) the other day after 5 miles, the engine was really hot pulled over and the engine red hot but the rad was cold!!
Thermostat i thought got a new the one with the plastic housing, pit on the car just same (hot engine,cold rad) put Thermostat in a bowl of boiling water nothing happen....
Back to the spares shop got a new one fitted it still same, run engine without Thermostat engine warm, rad warm, hoses warm and the temp gauge at 70 instead of in the red,
Please tell me what is going on here
can 2 Thermostat be duff
Cheers
Hi my name is phil
x 5683
How long did you wait for them to open?
Yes, several can be duff, part of a duff batch probably.
wulfgar2k
5 mins but the engine was so hot by then.
Hi my name is phil
x 5683
5 mins would be adequate - some folks expect them to snap open when warmed.
wulfgar2k
So get another Thermostat and try again....
Hi my name is phil
Oldpug
x 94
Unread post by Oldpug »
I`ve worked on these TU engines for years and one out of a hundred just will not bleed properly.A few months ago I had the same symptoms as yours AFTER! refitting the head with new w/pump,stat etc.I was convinced I`d messed up the job somewhere, but spent hrs doing "force bleeding" etc and it suddenly came right.Dont ask me why,the cars still running like a dream.
x 1240
Unread post by Peter.N. »
That used to be a problem with XUD engines, many a head was cracked by inadequate bleeding so that could well be your problem. Disconnect one of the heater hoses and fill the system until water flows freely, if it doesn't, start the engine.
wulfgar2k
Thanks for all your help i will try in the mourning to bleed it and bleed it again, shall i open up the bleed vavle on the heater hose all the way or take off one of the hoses.. :?:
Cheers
Hi my name is phil
x 5683
Bleed valve should be fine - sometimes it helps to make a header tank, cut the bottom off a 2 coke bottle and shove it into the filler like s funnel, but tight, may need some blue tack to seal it sufficiently, then fill it right up (assistant helps) and open the bleed caps.
We did my son's 306 the other day and it went fine without the header tank.
addo
Sara Watson's Stalker
x 95
Unread post by addo »
I would first determine there is adequate coolant in the system! It may be well underfilled.
wulfgar2k
Still no luck....but the word is keep at it untill it works and a plastic milk carton seems to fits better and thanks to all of you.. :)
By the way it;s not getting me down yet...IT'S ONLY A CAR :lol: :lol:
Hi my name is phil
wulfgar2k
At it all day no luck yet..with the Thermostat.
Hi my name is phil
wulfgar2k
Snow here so had to leave it till later :x :x :x :x
Hi my name is phil
Oldpug
x 94
Just a thought?when you open the bleed screw at the stat` end of the cylinder head WITH the engine running do you get good jet of water??in other words are you getting good pressure in the system? It has been known for the impeller of the water pump to fail and not circulate the water.ie hot block/cold rad.
wulfgar2k
Oldpug been at it all day with coke bottles etc etc and still got hot engine + cold rad and get a great jet of water (like somebody having a *iss) and it is hot as my hand can tell you.
So back to the start and get a new thermostat the third one from a different spares place, i have had two new line Thermostats is there other makes around?????...it's to car spares on Sunaday then for me.
Also thanks for the info Oldpug.... :? :? :? :? :?
Hi my name is phil
