Thermostat
wulfgar2k
Thermostat
Hi
went out in the car( 306 1.6) the other day after 5 miles, the engine was really hot pulled over and the engine red hot but the rad was cold!!
Thermostat i thought got a new the one with the plastic housing, pit on the car just same (hot engine,cold rad) put Thermostat in a bowl of boiling water nothing happen....
Back to the spares shop got a new one fitted it still same, run engine without Thermostat engine warm, rad warm, hoses warm and the temp gauge at 70 instead of in the red,
Please tell me what is going on here
can 2 Thermostat be duff
Cheers
Cheers
Hi my name is phil
- x 5633
wulfgar2k
- x 5633
wulfgar2k
Oldpug
- x 93
I`ve worked on these TU engines for years and one out of a hundred just will not bleed properly.A few months ago I had the same symptoms as yours AFTER! refitting the head with new w/pump,stat etc.I was convinced I`d messed up the job somewhere, but spent hrs doing "force bleeding" etc and it suddenly came right.Dont ask me why,the cars still running like a dream.
- x 1240
wulfgar2k
- x 5633
Bleed valve should be fine - sometimes it helps to make a header tank, cut the bottom off a 2 coke bottle and shove it into the filler like s funnel, but tight, may need some blue tack to seal it sufficiently, then fill it right up (assistant helps) and open the bleed caps.
We did my son's 306 the other day and it went fine without the header tank.
addo
- Sara Watson's Stalker
- x 95
wulfgar2k
wulfgar2k
wulfgar2k
Oldpug
- x 93
Just a thought?when you open the bleed screw at the stat` end of the cylinder head WITH the engine running do you get good jet of water??in other words are you getting good pressure in the system? It has been known for the impeller of the water pump to fail and not circulate the water.ie hot block/cold rad.
wulfgar2k
Oldpug been at it all day with coke bottles etc etc and still got hot engine + cold rad and get a great jet of water (like somebody having a *iss) and it is hot as my hand can tell you.
So back to the start and get a new thermostat the third one from a different spares place, i have had two new line Thermostats is there other makes around?????...it's to car spares on Sunaday then for me.
Also thanks for the info Oldpug....
Hi my name is phil
