HDi Crank Pulley
jonnydrumm1967
HDi Crank Pulley
Unread post by jonnydrumm1967 »
Hi,I've noticed a hard rattle coming from the crank pulley area of my Xantia HDi when it's idling,it lessens as the revs rise up a bit.I'm concerned that the rubber bonding might be separating from the metal.
Looking on Ebay I saw there are now solid pulleys available for the HDi.Anyone know if they can be retro fitted? Would an XUD pulley fit? I've got a few of those lying about on old engines...
Thanks in advance.
2000 XANTIA HDi 110 SX Est
1992 205 GTI TD
1996 DISCOVERY TDI
2001 XANTIA HDi LX
1991 205 D Turbo
HDI
x 7
Unread post by HDI »
Just had the same problem with my HDI, fitted a one piece with no problems. Don't know if an XUD type can be fitted.
Now using '00 Xantia LX HDI, pov spec :(
My past Citroens :-
'00 Xantia SX HDI, now dead due to accident :(
'99 Xantia HDI 110 Exclusive, RIP :(
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
'79 CX2400 Pallas (scrapped :( )
& a couple of Peugeots !
x 8422
HDI wrote:Don't know if an XUD type can be fitted.
No, they're very different. Even the boss is different.
jonnydrumm1967
Cheers,thanks for the replies,was curious regarding the XUD one but will go for a solid pulley.
1992 205 GTI TD
1996 DISCOVERY TDI
2001 XANTIA HDi LX
1991 205 D Turbo
x 1941
Unread post by Paul-R »
Even though I had a pulley go on the Xsara last summer I wouldn't fit a solid one. The dual mass type perform a useful function (unlike the flywheels IMHO!) as they absorb some of the vibration from the engine
I suspect that you would have to consider changing the timing belt more often as well as, although it isn't cushioned directly by the bonded rubber, it would be stressed more.
HDI
x 7
The so called solid pulley is still a damper pulley, so there will be no issues with fitting it.
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
x 1941
Then why is it called solid?
HDI
x 7
The correct term is one piece :wink:
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
x 1941
Do you have a link for this one-piece pulley? I don't see how it can dampen harnonic vibrations without being dual mass.
DickieG
Monaco's youngest playboy
x 33
Unread post by DickieG »
Paul-R wrote:Do you have a link for this one-piece pulley? I don't see how it can dampen harnonic vibrations without being dual mass.
Here's a link to one complete with photo, Citroen now supply this single piece pulley under the part number of 0515.V6 for my HDi, so if Citroen specify it then I presume that a single piece pulley is OK.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
HDI
x 7
When I replaced the failed original on mine I was in a rush so didn't pay too much attention to the replacement. My guess is that it will be made from 2 parts and somehow rubber bonded together. Thus allowing differential movement between the 2 parts to perform as a harmonic damper.
One way or another it must be a damper pulley otherwise the crank would be at risk and engine vibration would be noticeable.
The original design obviously had problems, but having said that mine lasted over 170K miles, so maybe it was the failure mode rather than longevity which was the issue ?
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
x 1941
Difficult to say from the heavily branded photograph but it doesn't look as though it's NOT dual mass to me.
The one on the Xsara had covered about 160,000 miles so I don't see it as a weak part. I suspect the neew type is just cheaper to produce!
