Rubber cap on rear hc swollen [solved - was air inside]
Xaccers
x 188
Unread post by Xaccers »
At Finmere today, so thought while the lads were out in the woods spraying each other with white stuff (airsoft), I'd use the ramps and give Cassy's rear height control links a good lube.
I've noticed she seems to be riding a tiny bit low at the back, which may explain why she's always had a slightly firmer ride than other Xantias I've owned. I'm reticent to correct this though as she handles so well.
While checking all this I noticed that the rubber cap on the rear face of the hc is swollen and feels like it is full of fluid (one would presume lhm).
Is this normal? I'm sure when I've had a cover off before it was dry underneath.
DIY sphere tool
Stempy
Unread post by Stempy »
I was under the back of mine a couple of days back whilst checking out my sinking problem. I happened to pop off the HC cap while I was under there and it was perfectly dry and clean underneath, in fact looked as good as new, so I would imagine you may have a bit of blow by in there.
Lexia ponce
x 94
Unread post by citronut »
Xac
i quite offten see these dust cover's buldging, by usualy only find them just full of air,
i think this is down to the diaphram movement, just lift the edge of the dost cover and it will de/flatte,
regards malcolm
x 5691
citronut wrote:Xac
regards malcolm
Or anoint you with the green stuff :)
Xaccers
x 188
Well, I have been meaning to change hair conditioner :D
DIY sphere tool
x 94
Steve lets av a full sized shot of you new avitar then, my eye sight aint what it used to be :-** ,
or is it possible to make the avitar's clickable to open then to full/wide screen,
regards malcolm
jgra1
(Donor 2021)
x 36
Unread post by jgra1 »
Xac I think I had this once.. from memory, it was a leaking seal within the HC..
x 8470
jgra1 wrote:Xac I think I had this once.. from memory, it was a leaking seal within the HC..
Yes, its rare but I had a leaky roll corrector on an Activa once. These are the same as a height corrector but has no damping and lies on its side...
I believe overhaul kits are available. Have a natter with Pleiades.
Replacing the seals is dead easy once you know the trick.
In any event, I have one you may have....
x 5691
Mylène Farmer.
jgra1
(Donor 2021)
x 36
thanks Malcolm ;)
x 5691
citronut wrote:Steve lets av a full sized shot of you new avitar then, my eye sight aint what it used to be :-** ,
regards malcolm
I tried to place a clickable avatar but never got it to work.
She sounds as good as she looks :) Not bad for a 48-year old!
x 94
oooooh you made me knee's go all wobbly,
i like how a thread about rubber cap's turned to s e x
regards malcolm
x 8470
citronut wrote: i like how a thread about rubber cap's turned to s e x
If you think long and hard enough, there is a connection Malcolm :lol: :lol:
Got to agree though, she is one smokin' hot lady :P
x 5691
citronut wrote:oooooh you made me knee's go all wobbly,
regards malcolm
She looks pretty good in this:
Souviens-Toi Du Jour.... Not her best song by a long way but 'smoking' :)
addo
Sara Watson's Stalker
x 95
Unread post by addo »
Do they post Xantia height corrector photos on the Mylène Farmer forum? :lol:
Julia Bradbury wrote:That old hornbag is pinching my fan base.
