At Finmere today, so thought while the lads were out in the woods spraying each other with white stuff (airsoft), I'd use the ramps and give Cassy's rear height control links a good lube.
I've noticed she seems to be riding a tiny bit low at the back, which may explain why she's always had a slightly firmer ride than other Xantias I've owned. I'm reticent to correct this though as she handles so well.
While checking all this I noticed that the rubber cap on the rear face of the hc is swollen and feels like it is full of fluid (one would presume lhm).
Is this normal? I'm sure when I've had a cover off before it was dry underneath.
Rubber cap on rear hc swollen [solved - was air inside]
Xaccers
- x 188
DIY sphere tool
DIY sphere tool
Stempy
I was under the back of mine a couple of days back whilst checking out my sinking problem. I happened to pop off the HC cap while I was under there and it was perfectly dry and clean underneath, in fact looked as good as new, so I would imagine you may have a bit of blow by in there.
Lexia ponce
Lexia ponce
- x 94
- x 5672
Xaccers
- x 188
Well, I have been meaning to change hair conditioner
DIY sphere tool
DIY sphere tool
- x 94
jgra1
- (Donor 2021)
- x 36
- x 8418
Yes, its rare but I had a leaky roll corrector on an Activa once. These are the same as a height corrector but has no damping and lies on its side...jgra1 wrote:Xac I think I had this once.. from memory, it was a leaking seal within the HC..
I believe overhaul kits are available. Have a natter with Pleiades.
Replacing the seals is dead easy once you know the trick.
In any event, I have one you may have....
- x 5672
I tried to place a clickable avatar but never got it to work.citronut wrote:Steve lets av a full sized shot of you new avitar then, my eye sight aint what it used to be,
or is it possible to make the avitar's clickable to open then to full/wide screen,
regards malcolm
She sounds as good as she looks
- x 94
- x 8418
- x 5672
She looks pretty good in this:citronut wrote:oooooh you made me knee's go all wobbly,
i like how a thread about rubber cap's turned to s e x
regards malcolm
Souviens-Toi Du Jour.... Not her best song by a long way but 'smoking'
addo
- Sara Watson's Stalker
- x 95
