CITROEN C5 AIRBAG FAULT+SERVICE LIGHT HOW DO I GET IT OFF
gazzas c5
Hi folks my c5 hdi exclusive shows airbag fault and service light stays on when car is started up how do i get them off?or any advice cheers peeps much appreciated,thanks
CITROEN C5 2.0 HDI VTR 04 REG
CITROEN C5 2.0 16V EXCLUSIVE 53 REG
CITROEN C5 2.0 HDI EXCLUSIVE 52 REG
CITROEN C5 2.2 HDI EXCLUSIVE AUTOMATIC 54 REG FACELIFT MODEL
CITROEN C5 1.6 HDI VTR 05 REG FACELIFT MODEL
dnsey
- x 19
gazzas c5
no havent sourced the fault,i have heard its a common fault on citroens
addo
- Sara Watson's Stalker
- x 95
I believe some people suggest a 124g hollow point in 9mm. Careful aim is required to minimise damage to other parts of the dash.
Less destructive types might suggest looking up the nearest "Lexia" holder near you (look up the SuperSticky topic Lexia Locations), and negotiating with the appropriate Forum member for a diagnostic session. It's going to simplify the fault repair a whole lot.
Regards, Adam.
Regards, Adam.
- x 5670
gazzas c5
airbag fault and sevrvice light citroen c5
Hi Steve,will check the connections under the seats 2moro,will the light go off if its the contacts?cheers thanks Gary
- x 5670
Re: airbag fault and sevrvice light citroen c5
Only if that is the problem - which it often is.gazzas c5 wrote:Hi Steve,will check the connections under the seats 2moro,will the light go off if its the contacts?cheers thanks Gary
May take up to five trips before it clears.
gazzas c5
airbag fault and service light citroen c5
Have you got any tips for me Steve?How u mean 5 trips?cheers or if it isnt the connections what else can it be?thanks
addo
- x 95
- x 5670
Re: airbag fault and service light citroen c5
ECU needs up to five runs without the fault being recognised before the code is cleared and the lights go out.gazzas c5 wrote:Have you got any tips for me Steve?How u mean 5 trips?cheers or if it isnt the connections what else can it be?thanks
If it isn't that then without replacing bits of the system in the hope of getting the right one is to run a diagnostic session on it.
addo
- x 95
With the Xantia II's Teves system, one "crash stop" to activate the ABS puts the light out! (Assuming the fault is actually fixed.)
I tried this when in a CBF mood after accidentally disconnecting a sensor then starting the car.
FYI the Lexia stuff is getting that cheap now, you could play with it for about £125 to your doorstep: http://www.buyobd.com/index.php?main_pa ... ducts_id=9
- x 1052
try this thread > http://www.frenchcarforum.co.uk/forum/v ... ght=airbag
gazzas c5
airbag fault light
Will try it when i have free time,do i need to take the drawer out of the pass seat?what do i do to access the connector under the pass seat?
- x 1052
gazzas c5
i have pulled up the passenger carpet ,found 3 connectors,is it any of them?if so what one is it and what should i do?cheers peeps
