CITROEN C5 AIRBAG FAULT+SERVICE LIGHT HOW DO I GET IT OFF
gazzas c5
Unread post by gazzas c5 »
Hi folks my c5 hdi exclusive shows airbag fault and service light stays on when car is started up how do i get them off?or any advice cheers peeps much appreciated,thanks
CITROEN C5 2.0 HDI VTR 04 REG
CITROEN C5 2.0 16V EXCLUSIVE 53 REG
CITROEN C5 2.0 HDI EXCLUSIVE 52 REG
CITROEN C5 2.2 HDI EXCLUSIVE AUTOMATIC 54 REG FACELIFT MODEL
CITROEN C5 1.6 HDI VTR 05 REG FACELIFT MODEL
dnsey
x 19
Unread post by dnsey »
Have you located and repaired the actual fault?
gazzas c5
no havent sourced the fault,i have heard its a common fault on citroens
addo
Sara Watson's Stalker
x 95
Unread post by addo »
I believe some people suggest a 124g hollow point in 9mm. Careful aim is required to minimise damage to other parts of the dash.
Less destructive types might suggest looking up the nearest "Lexia" holder near you (look up the SuperSticky topic Lexia Locations), and negotiating with the appropriate Forum member for a diagnostic session. It's going to simplify the fault repair a whole lot.
Regards, Adam.
x 5672
Check the connections under the front seats. These sometimes come loose/disconnect when adjusting the seats or cramming things under them.
gazzas c5
airbag fault and sevrvice light citroen c5
Hi Steve,will check the connections under the seats 2moro,will the light go off if its the contacts?cheers thanks Gary
x 5672
Re: airbag fault and sevrvice light citroen c5
gazzas c5 wrote:Hi Steve,will check the connections under the seats 2moro,will the light go off if its the contacts?cheers thanks Gary
Only if that is the problem - which it often is.
May take up to five trips before it clears.
gazzas c5
airbag fault and service light citroen c5
Have you got any tips for me Steve?How u mean 5 trips?cheers or if it isnt the connections what else can it be?thanks
addo
x 95
Why not send a message to "Superloopy"? He's near Newcastle and has a Lexia. Perhaps it will help?
x 5672
Re: airbag fault and service light citroen c5
gazzas c5 wrote:Have you got any tips for me Steve?How u mean 5 trips?cheers or if it isnt the connections what else can it be?thanks
ECU needs up to five runs without the fault being recognised before the code is cleared and the lights go out.
If it isn't that then without replacing bits of the system in the hope of getting the right one is to run a diagnostic session on it.
addo
x 95
With the Xantia II's Teves system, one "crash stop" to activate the ABS puts the light out! (Assuming the fault is actually fixed.)
I tried this when in a CBF mood after accidentally disconnecting a sensor then starting the car.
FYI the Lexia stuff is getting that cheap now, you could play with it for about £125 to your doorstep: http://www.buyobd.com/index.php?main_pa ... ducts_id=9
x 1052
Unread post by wheeler »
gazzas c5
airbag fault light
Will try it when i have free time,do i need to take the drawer out of the pass seat?what do i do to access the connector under the pass seat?
x 1052
The connectors in question are under the carpet where the passangers feet rest not under the seat, the carpet pretty much just pulls up.
gazzas c5
i have pulled up the passenger carpet ,found 3 connectors,is it any of them?if so what one is it and what should i do?cheers peeps
