Hi All..
Got a Xantia HDi in, with the diagnostic light on... Lexia says Low Fuel Pressure signal reading..
Car starts and runs, but is limmped to 3k revs flat out.... however, after a couple of revs it will suddenly go up to MAX revs, but then theres an awfull diesel KNOCK.... its not your average knock, its that bad the engine shudders with it, then goes to stall.... any HDi owners tell me if this is an injector playing silly buggers??? Next timeIll get Lexia on it and do a Parameter Readings and see what happens....
If however, HDi guys arent sure, Ill update this if and when I find out...
Cheers
Paul
Poorly HDi Xantia
citroenxm
- Fallen Hero
- x 70
Poorly HDi Xantia
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- x 8395
DHallworth
- x 167
citroenxm
- Fallen Hero
- x 70
Hey D...
Cheers, Im suspecting injectors too.... I cannot see it being the engine pump, as they either work not NOT at all...
The tank pump has just been changed, so Im looking injectors too..
Jim, High pressure side....
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
DickieG
- Monaco's youngest playboy
- x 33
Pull out the pressure regulator on the end of the pump and check for metal debris, also give the electric connectors a spray with contact cleaner and wiggle concentrating on the pump pressure regulator and fuel rail pressure sensor.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
citroenxm
- Fallen Hero
- x 70
Hi all..
Just to wrap this up - the fault on the fuel system WAS exactly what the Lexia was telling me...
The Fuel Rail Pressure sensor was duff... a replacement and we are away!!
Good as new!
Paul
Good as new!
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- x 8395
citroenxm
- Fallen Hero
- x 70
Yea, quite pleased with that, just need to fit some brake pads and put steely wheels back on and she can go! and has to go!
A nice car too, 101k, recent clutch, exhaust, windscreen, and Ive fitted electric leather trim too.
TAX And Test too!
Paul
TAX And Test too!
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
