Hi all
My Xantia 2.1TD has a breather hose split but i cant seem too find it on Service Citroen
As most will know im not that good at descriptions but here goes
Its on the front of the engine and goes from the sump upto the rocker cover just underneath the inlet manifold cover.it appears to be 2 seperate pipes with a join approx 6" down from the rocker cover.it has perished where it goes onto the rocker cover.
Any pointers as to a diagram/part number would be appreciated
Colin
oil breather hose identification required
colin i belive this is price and part No. of the pipe you require,
after entering your last 8 digits of your VIN No., then you click on lubrication in the engine sectionon the first menu page, then select OIL FILLER DECANTING UNIT UNIONS, this give a diagram of all the breather hose's,
Part Number Description Quantity Price excl. VAT Price incl. VAT Total incl. VAT Selection
00001192K8 OIL VAPOR HOSE 16.89 GBP 19.85 GBP 19.85 GBP
at its top end it attatch's at the top of the cranck case just below the cam cover joint, and is No. 12 on service citroen's exploded view,
regards malcolm
regards malcolm
