oil breather hose identification required
admiral51
x 389
Unread post by admiral51 »
Hi all
My Xantia 2.1TD has a breather hose split but i cant seem too find it on Service Citroen :oops:
As most will know im not that good at descriptions but here goes :lol:
Its on the front of the engine and goes from the sump upto the rocker cover just underneath the inlet manifold cover.it appears to be 2 seperate pipes with a join approx 6" down from the rocker cover.it has perished where it goes onto the rocker cover.
Any pointers as to a diagram/part number would be appreciated :)
Colin
x 94
Unread post by citronut »
give us your last 8 digits of your chassis No. and i will stick it into service citroen to check it out for you
regards malcolm
admiral51
x 389
Hi Malcolm
Here tis number in full
Cheers
Colin
x 94
colin i belive this is price and part No. of the pipe you require,
after entering your last 8 digits of your VIN No., then you click on lubrication in the engine sectionon the first menu page, then select OIL FILLER DECANTING UNIT UNIONS, this give a diagram of all the breather hose's,
00001192K8 OIL VAPOR HOSE 16.89 GBP 19.85 GBP 19.85 GBP
at its top end it attatch's at the top of the cranck case just below the cam cover joint, and is No. 12 on service citroen's exploded view,
regards malcolm
admiral51
x 389
Hi Malcolm
You are indeed 100% correct that is indeed the pipe i am after :D :D
Must take more time to understand the new service layout :lol: :lol:
Cheers
Colin
x 94
you dont need to understand the new system Colin, in the free drop down box if you click on the ERUO 5 parts documentation it breing you to the old style service,
regards malcolm
admiral51
x 389
Cheers Malcolm, that seems much better :D
Colin
