problem with my xantia.sunspetion,breaks
argopanos
Unread post by argopanos »
hi to all of you.sorry about my english ,i m from greece.i tryied to put out the air from the system,but i did it as the motor was running in normal position(sunsp).a lot of lhm came out and by that time i have no breaks no suspention.nothing happens if i put it to hight or low,the car is not movig at all.please help.thank you for reading this.
x 1459
Unread post by xantia_v6 »
We will try to help you but we need a little more information.
How did you try to bleed the air? What did you loosen?
Is the LHM tank now empty?
argopanos
in the frond central sfhear is a 12' bolt.this bolt i unscrew it. now the lhm level is good possition,not full but there is some.
x 1488
Did you take the bolt right out? Have you now refitted the bolt, and still got no suspension pressure?
Don't worry about your english - I'm sure we can figure it out!
argopanos
yes.all now its in place.the front car is in normal hight and the rear is in low hight. i want to thank you for your time,bythe way
x 5672
Re: problem with my xantia.sunspetion,breaks
argopanos wrote:in the frond central sfhear is a 12' bolt.this bolt i unscrew it. now the lhm level is good possition,not full but there is some.
Did you completely remove the bleed screw (bolt)?
You only need to open it about ¼-½ a turn.
If it was completely removed then you may have lost the tiny ball bearing that is the seal. This would leave the bleed bypass open and your system will not pressurise.
You will need to hunt around for the ball and replace it on the end of the spring then re-tighten the bleed screw (bolt). Take care not to over tighten it as you will damage the brass seat that the ball sits in and again it won't seal.
If you haven't lost the ball then you may have overtightened it and the seal is already damaged.
argopanos
thank you for your time ,you were very helpfull.first thing in the morning,i look.
argopanos
i found the ball under my car next morning.now its ok and have no problems.once again thank you very mutch for your help and time. :D
x 8391
argopanos wrote:i found the ball under my car next morning.now its ok and have no problems.once again thank you very mutch for your help and time. :D
Excellent :D You were lucky! Those balls usually disappear, or at least in the UK they do :lol:
wotwot
(Donor 2021)
x 4
Unread post by wotwot »
Dont mean to make light of our greek friend love the greek islands. but
must be a big car with that 12 foot bolt sticking out the front (12'!!!!),
and the ball bearing would have been easy to find it would have been about 10 foot tall :shock: :lol:
wotwot
(Donor 2021)
x 4
Christ think how big his toolbox must be. :lol:
x 8391
:lol:
x 5672
I think it will be a keyboard mapping error :)
