problem with my xantia.sunspetion,breaks
argopanos
hi to all of you.sorry about my english ,i m from greece.i tryied to put out the air from the system,but i did it as the motor was running in normal position(sunsp).a lot of lhm came out and by that time i have no breaks no suspention.nothing happens if i put it to hight or low,the car is not movig at all.please help.thank you for reading this.
- x 1459
argopanos
in the frond central sfhear is a 12' bolt.this bolt i unscrew it. now the lhm level is good possition,not full but there is some.
- x 1489
argopanos
yes.all now its in place.the front car is in normal hight and the rear is in low hight. i want to thank you for your time,bythe way
- x 5672
Re: problem with my xantia.sunspetion,breaks
Did you completely remove the bleed screw (bolt)?argopanos wrote:in the frond central sfhear is a 12' bolt.this bolt i unscrew it. now the lhm level is good possition,not full but there is some.
You only need to open it about ¼-½ a turn.
If it was completely removed then you may have lost the tiny ball bearing that is the seal. This would leave the bleed bypass open and your system will not pressurise.
You will need to hunt around for the ball and replace it on the end of the spring then re-tighten the bleed screw (bolt). Take care not to over tighten it as you will damage the brass seat that the ball sits in and again it won't seal.
If you haven't lost the ball then you may have overtightened it and the seal is already damaged.
argopanos
thank you for your time ,you were very helpfull.first thing in the morning,i look.
argopanos
- x 8397
wotwot
- (Donor 2021)
- x 4
wotwot
- (Donor 2021)
- x 4
- x 8397
- x 5672
