Xantia 2L HDI 2000 reg, rattle
nat
Unread post by nat »
Hi
I seem to have something very wrong with my car :( I'll try and give as many details as possible.
there is a very loud rattling that is coming from the engine bay somewhere on the aux belt and the belt itself is spitting bits or rubber every so often,
also when looking at the little window into the aircon fluid it seems very bubbly and inconsitent and the aircon buttone has no effect (very different to how it used to look).
the power steering is coming and going and feels pulsey when driving.
finally, the battery light comes on for a second or so every few seconds.
the car lifts up although a little slower than normal and the ride and brakes seem fine.
Any ideas?
Nathanael
Xaccers
x 188
Unread post by Xaccers »
The Aux belt drives your aircon compressor, hydraulic pump (steering/brakes/suspension) and alternator.
Get the belt changed ASAP.
While it's off check the belt tensioners for any play and replace if required.
Also check that you pump, compressor and alternator for any play incase they've rattled themselves loose.
If the belt goes when driving, best case scenario you lose suspension and power steering but your accumulator sphere has enough residual pressure to enable safe braking.
Worst case: bits of belt fly into your cambelt damaging that and the engine, your accumulator sphere is flat so you lose brakes and slam into an oncoming school bus sending 70 kids off a bridge to a firey death.
DIY sphere tool
Chris570
x 36
Unread post by Chris570 »
on that engine it has a dual mass pully on the crank that wears out, check it out NOW, but yeah you'll def need a new belt
nat
thanks for the quick replys
what is this dual mass pully? is it easily changed? easy to spot and inspect?
rmunns
x 9
Unread post by rmunns »
Can we have a definitive answer, please, regarding Dual-mass flywheels?
Is one fitted to Xantia Hdi's? Either or 90 or 110 or both?
{{{There are recent contradictory postings on this}}}.
Xaccers
x 188
rmunns wrote:Can we have a definitive answer, please, regarding Dual-mass flywheels?
My understanding is that Xantia Hdi's didn't get the DMF but did get a DM crank pulley.
DIY sphere tool
The Seasider
Unread post by The Seasider »
I believe that ^^^^^^ to be correct.... HDi have DM Pulley NOT DM Flywheel ...
On a side note DMF's are a sack of Poo Poo ..... Best you can do with em is WELD the Bastids together .....(Around the edge)
Done it on Transits, Range Rover Diesels & BMW's ....
WHOEVER INVENTS a method of Splitting them apart & replacing/refurbing the Springs & Bearings WILL MAKE A FORTUNE!!!!!!!!!!!!!!
I have just NEVER understood WHY they are NOT "Splitterble"
HDI Dave
x 3
Re: Xantia 2L HDI 2000 reg, rattle
Unread post by HDI Dave »
nat wrote: there is a very loud rattling that is coming from the engine bay somewhere on the aux belt and the belt itself is spitting bits or rubber every so often,
Any ideas?
I had all these,turned out to be the crank pulley,as mentioned.Oh and it knackered the belt quite badly,but didn't break.
^^^ Here's my 'fix':
http://www.frenchcarforum.co.uk/forum/v ... sc&start=0
1999 Xantia LX 2.0 HDI 110 Rusteration project...
