405 Rear Caliper Tool
addo
Sara Watson's Stalker
x 95
Unread post by addo »
What are people using? I've just found mine are all but frozen solid; no movement either way with the bleeder cracked open.
Thanks, Adam.
spider
x 77
Unread post by spider »
From memory, just a flat bar ? :?:
Andy.
addo
x 95
It's Series 1½, the piston face notches aren't clean across like a Xantia piston. They're triangular or veed, starting from nothing at the inward tip to deepen at the outer edge.
x 94
Unread post by citronut »
Adam something like this ebay listting should do for all your calliper requirements
260574696272
regards malcolm
addo
x 95
Thanks for the pointer. I just discovered a new Google trick - you type in "ebay item #####" where the hashes are the item number - it brings up the exact link and page faster than Fleabay itself.
Tool is cheap enough; I've seen them under another brand locally but somewhat dearer. Time to find out if the seller will bend his rules about posting overseas. :roll:
Are the rear 405 calipers a LH thread? Something (memory?) tells me they are.
x 5683
If you highlight the number and right click then select "Search Google for..." it comes up immediately. - this is Epiphany that is a bit stripped down.
Firefox has a search bar to the right of the address bar with drop downs for Google, Yahooooo! Amazon and eBay, among others.
x 94
that Sealey tool is very cheap, also if you just do a google search for brake calliper wind back tool, you will find loads of them, so you might find an ebayer willing to ship to AUZ,
regards malcolm
addo
x 95
Yes, I looked up Sealey's RRP and it's £120. :shock: Forty quid sounds much nicer, even if I pay near the same again for carriage.
I've a hunch there's the odd FCF member who'll play agent-designate in the event of boneheaded Ebay sellers. De-SORNed the Alfa today (well, our local equivalent) so some pressure is off - back with two working cars.
addo
x 95
Tool purchased, but it's coming via FCF Couriers International PLC, and their sub-agents Royal Mail. Looking forward to seeing what more mischief I can do...
addo
x 95
I have to conclude there is a postie somewhere, who's recently added a Sealey brake tool set to his kit. :? £46-odd for the tool set, more than that for airmail; two weeks and no sign thereof.
Will probably invoke Murphy and buy another one on Friday...
addo
x 95
Postie turned up, smelling of DOT4, hands blackened with brake soot, waving my Sealey tool set. Yay! :lol:
Two weeks in transit is deffo the slow boat...
addo
x 95
Not true! The 32 days it took a 405 caliper seal kit to come from Germany by airfreight is my present record-holder.
Sealey tool T-bar bends easily. Well, it does when your 405 caliper is so massively seized.
Now have one rebuilt caliper installed, one to go.
jgra1
(Donor 2021)
x 36
Unread post by jgra1 »
good stuff Adam :D
32 days is pretty dire..
