What are people using? I've just found mine are all but frozen solid; no movement either way with the bleeder cracked open.
Thanks, Adam.
405 Rear Caliper Tool
spider
- x 77
addo
- Sara Watson's Stalker
- x 95
- x 94
addo
- x 95
Thanks for the pointer. I just discovered a new Google trick - you type in "ebay item #####" where the hashes are the item number - it brings up the exact link and page faster than Fleabay itself.
Tool is cheap enough; I've seen them under another brand locally but somewhat dearer. Time to find out if the seller will bend his rules about posting overseas.
Are the rear 405 calipers a LH thread? Something (memory?) tells me they are.
Onlinemyglaren
- x 5634
- x 94
addo
- x 95
Yes, I looked up Sealey's RRP and it's £120.
Forty quid sounds much nicer, even if I pay near the same again for carriage.
I've a hunch there's the odd FCF member who'll play agent-designate in the event of boneheaded Ebay sellers. De-SORNed the Alfa today (well, our local equivalent) so some pressure is off - back with two working cars.
addo
- x 95
addo
- x 95
addo
- x 95
addo
- x 95
Not true! The 32 days it took a 405 caliper seal kit to come from Germany by airfreight is my present record-holder.Two weeks in transit is deffo the slow boat...
Sealey tool T-bar bends easily. Well, it does when your 405 caliper is so massively seized.
Now have one rebuilt caliper installed, one to go.
jgra1
- (Donor 2021)
- x 36
