Folks, I am again looking for some advice. Last week I had some work done on the car to get it through the MOT. this included two new Citroen spheres on the front. Since then I have noticed that the front nearside has almost no suspension travel. Car is a non-hydractive model.
Is there anything simple I can check which may be causing this, or could it be that one of the replacement spheres is defective (they were definitely changed)?
Cheers
Ainslie
Xantia, one bouncy corner.
- x 1460
Old-Guy
- x 26
I suggest you immediately contact the garage that did the work, explain the problem and arrange to take it back for them to inspect and rectify - if there is no suspension travel, the only possible cause is that the sphere on that corner is defective.
Nobody else (you included) should do anything to the car - otherwise the garage can justifiably claim that it's not their fault.
Gingerposer
- x 6
