Xantia, one bouncy corner.
Gingerposer
x 6
Unread post by Gingerposer »
Folks, I am again looking for some advice. Last week I had some work done on the car to get it through the MOT. this included two new Citroen spheres on the front. Since then I have noticed that the front nearside has almost no suspension travel. Car is a non-hydractive model.
Is there anything simple I can check which may be causing this, or could it be that one of the replacement spheres is defective (they were definitely changed)?
Cheers
Ainslie
x 1463
Unread post by xantia_v6 »
Could one of the spheres be the wrong type?
It should be easy enough to depresurise the system and swap left too right, and see if the fault moves.
Old-Guy
x 26
Unread post by Old-Guy »
I suggest you immediately contact the garage that did the work, explain the problem and arrange to take it back for them to inspect and rectify - if there is no suspension travel, the only possible cause is that the sphere on that corner is defective.
Nobody else (you included) should do anything to the car - otherwise the garage can justifiably claim that it's not their fault.
Gingerposer
x 6
I shall do that tomorrow, the garage is conveniently near my workplace.
