Theories on driveshafts please
MikeT
- x 232
On a PSA V6 3.0 what would/could be the reasons for having to replace both drivehshafts at ~80K miles?
KP
- x 27
MikeT
- x 232
spider
- x 77
A good motor factor may be able to supply replacement driveshafts, even for a V6 at a semi sensible price.
I know the ABS rings are not readily available separately, as I wanted one for a 406 2.0 as it had become detached (took a while to figure that ABS fault out!) , but there were not so. I've heard of people attempting to weld the ABS ring back but its never quite right if you do manage it.
Andy.
KP
- x 27
- x 1487
spider
- x 77
Oh I know, I just mentioned I had seen it done but its never quite right if you do attempt it. It's best classed as an emergency repair (or ignore it and the ABS light till you get a new shaft) , but I've seen odd ABS problems caused by a stationary ring while moving, resulting in lack of front brakes (as EBFD and ABS 'decided' that wheel was locked)KP wrote:Welding it back wouldn't be good as it would mean the shaft was out of balance and the ring would never run quite true to be honest..
Andy.
HDI
- x 7
If it's due to ABS rings then the reason is self explanatory, otherwise an aggressive driver could see them off that quickly easily !!
Now using '00 Xantia LX HDI, pov spec
My past Citroens :-
'00 Xantia SX HDI, now dead due to accident
'99 Xantia HDI 110 Exclusive, RIP
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
'79 CX2400 Pallas (scrapped
& a couple of Peugeots !
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
cachaciero
- x 9
FWIW I know that on a CX driving across rough ground on high suspension could kill the tri axe extremely quickly, please please don't ask me how I know that
cachaciero
cachaciero
2006 Toyota Prius T Spirit
2001 2.2 C5 Exclusive SE
1996 XM 2.1 TD Auto VSX
1987 CX 2.5 Gti Turbo II dead
1984 Ford Scorpio
1981 CX 2.4 Pallas Auto
Renault 21
1220 GS Club
Rover P6 2000TC
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
DickieG
- Monaco's youngest playboy
- x 38
Re: Theories on driveshafts please
If the car had PSA wheels without a centre hole to assist wheel balancing I can quite believe that the driveshafts may have been changed in desperation at trying to get rid of vibration.MikeT wrote:On a PSA V6 3.0 what would/could be the reasons for having to replace both drivehshafts at ~80K miles?
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
- x 94
falling-out-with-my-car
- x 25
sounds like a previous owner was a little heavy on the throttle and liked the sounds of screeching tyres wheelspinning away from a standing start.
a good way to kill driveshafts off by 80,000 miles if n ot before that.
regards Nigel.
regards Nigel.
