Theories on driveshafts please
MikeT
x 232
Unread post by MikeT »
On a PSA V6 3.0 what would/could be the reasons for having to replace both drivehshafts at ~80K miles?
KP
x 27
Unread post by KP »
Possibly been driven over rough ground at some point in its life and the boots have been caught and after a while the grease has been lost before the boot has been replaced leading to high wear rate already being then set in to the joints?
Or just badly made :)
MikeT
x 232
I failed to add, this a manual box if it makes any difference. Also, apparently the ABS rings can't be bought seperately, you have to buy them on the D/S.
KP
x 27
Unread post by KP »
Can imagine the price of them new then :(
These may help....
Driveshafts on eBay
spider
x 77
Unread post by spider »
A good motor factor may be able to supply replacement driveshafts, even for a V6 at a semi sensible price.
I know the ABS rings are not readily available separately, as I wanted one for a 406 2.0 as it had become detached (took a while to figure that ABS fault out!) , but there were not so. I've heard of people attempting to weld the ABS ring back but its never quite right if you do manage it.
Andy.
KP
x 27
Unread post by KP »
Welding it back wouldn't be good as it would mean the shaft was out of balance and the ring would never run quite true to be honest..
x 1456
What's the failure of the shafts? Outer CVs / Inner tir-axes / ABS ring problems?
Maybe the previous owner liked leaving it on full lock and wrecked the CVs, or had a vicious turn out of his drive / road that he liked to take at full power on full lock :twisted:
spider
x 77
KP wrote:Welding it back wouldn't be good as it would mean the shaft was out of balance and the ring would never run quite true to be honest..
Oh I know, I just mentioned I had seen it done but its never quite right if you do attempt it. It's best classed as an emergency repair (or ignore it and the ABS light till you get a new shaft) , but I've seen odd ABS problems caused by a stationary ring while moving, resulting in lack of front brakes (as EBFD and ABS 'decided' that wheel was locked)
Andy.
HDI
x 7
Unread post by HDI »
If it's due to ABS rings then the reason is self explanatory, otherwise an aggressive driver could see them off that quickly easily !!
Now using '00 Xantia LX HDI, pov spec :(
My past Citroens :-
'00 Xantia SX HDI, now dead due to accident :(
'99 Xantia HDI 110 Exclusive, RIP :(
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
'79 CX2400 Pallas (scrapped :( )
& a couple of Peugeots !
cachaciero
x 9
Unread post by cachaciero »
FWIW I know that on a CX driving across rough ground on high suspension could kill the tri axe extremely quickly, please please don't ask me how I know that :-)
cachaciero
2006 Toyota Prius T Spirit
2001 2.2 C5 Exclusive SE
1996 XM 2.1 TD Auto VSX
1987 CX 2.5 Gti Turbo II dead
1984 Ford Scorpio
1981 CX 2.4 Pallas Auto
Renault 21
1220 GS Club
Rover P6 2000TC
MikeT
x 232
Some good insight in the replies, thank you!
DickieG
Monaco's youngest playboy
x 38
Re: Theories on driveshafts please
Unread post by DickieG »
MikeT wrote:On a PSA V6 3.0 what would/could be the reasons for having to replace both drivehshafts at ~80K miles?
If the car had PSA wheels without a centre hole to assist wheel balancing I can quite believe that the driveshafts may have been changed in desperation at trying to get rid of vibration.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
x 94
Unread post by citronut »
i have welded an ABS ring back together with no advers problems, and it had split, as well as comeing adrift
regards malcolm
falling-out-with-my-car
x 25
sounds like a previous owner was a little heavy on the throttle and liked the sounds of screeching tyres wheelspinning away from a standing start.
a good way to kill driveshafts off by 80,000 miles if n ot before that.
regards Nigel.
