any body know how i can get the blaupunkt ph1/d stereo in the xantia recoded or decoded? i dont know the code and i have used a code calculator myself, and got three other separate people to find out the code for me on a forum,, and we all get the same code which the radio is not accepting, which means it must have been reprogrammed to something else at some point...
therefore i require someone to reprogram it,,any ideas anyone?
blaupunkt stereo help please
- x 8386
This calculator is known to be a good 'un...
Worked for me twice now
Follow the instructions in the thread absolutely precisely
i3
Jim,,the calculator is good indeed
,,,it works fine,,and i have followed the instructions exactly,,, i got the exact same code that three other people got,,,however,,as i mentioned,,it seems as though there is some further problem which requires the stereo to be connected to a computer for reprogramming/decoding/recoding....do you know any one that can help in this regard Jim?
DickieG
- Monaco's youngest playboy
- x 38
i3
citroenxm
- Fallen Hero
- x 70
The calculator only works if the stereo is absolutly ALL orgininal..
If its had work donw be a programmer in the past then it wont work from the Serial code!
Ive had a couple like this - due to that, written them off as spares... and bought others off the Bay..
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
i3
citroenxm
- Fallen Hero
- x 70
Simon99
You should be able to get the correct code from this very helpful forum:
http://forum.eserviceinfo.com/viewforum.php?f=8
Have to register first then post make, model, serial number etc. of radio. You will have to remove unit to read serial number etc.
If your radio isn't accepting any more codes leave it swicthed on with ignition for a few hours until it reads "code" again.
Hope they can help.
Hope they can help.
2002 C5 2.0 16v Estate
2001 C5 2.2hdi Hatchback
1998 Xantia 1.9td Estate
Simon99
Simon99
citroenxm
- Fallen Hero
- x 70
Simon99,
NO thats not the case with Xantias
Thats only the case with C5's onwards... Xantia Mk.2's still use the older "Code in the Radio" system.. and with the case of S2 Xantia Clarion units in they need the Code chip Reading .... and cannot be decoded from the serieal, like Blaupunkts...
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
DickieG
- x 38
- x 8386
i3
