blaupunkt stereo help please
i3
Unread post by i3 »
any body know how i can get the blaupunkt ph1/d stereo in the xantia recoded or decoded? i dont know the code and i have used a code calculator myself, and got three other separate people to find out the code for me on a forum,, and we all get the same code which the radio is not accepting, which means it must have been reprogrammed to something else at some point...
therefore i require someone to reprogram it,,any ideas anyone?
x 8176
This calculator is known to be a good 'un...
Worked for me twice now :D
Follow the instructions in the thread absolutely precisely :wink:
i3
Unread post by i3 »
Jim,,the calculator is good indeed :) ,,,it works fine,,and i have followed the instructions exactly,,, i got the exact same code that three other people got,,,however,,as i mentioned,,it seems as though there is some further problem which requires the stereo to be connected to a computer for reprogramming/decoding/recoding....do you know any one that can help in this regard Jim?
DickieG
Monaco's youngest playboy
x 38
Unread post by DickieG »
I take it you know that having entered the code you must press button 6 to verify the code?
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
i3
Unread post by i3 »
yes...i pressed 6 to verify the code,,,i think it may have got reprogrammed at some point therefore the code that is being generated by the serial number isnt working....?
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
The calculator only works if the stereo is absolutly ALL orgininal..
If its had work donw be a programmer in the past then it wont work from the Serial code!
Ive had a couple like this - due to that, written them off as spares... and bought others off the Bay..
Paul
A very sad...
1994 XM 2.1 d auto
i3
Unread post by i3 »
thats why im looking for someone who can program it,,or a replacement one... i have out a wanted post in the for sales/wanted forum... no response yet,,,ive been searching ebay,,,but cant find any yet....any ideas?
citroenxm
Fallen Hero
x 70
oooooo
I could very well have one then!!!
Ill check the stocks and working conditions for you tonight!
Paul
A very sad...
1994 XM 2.1 d auto
Simon99
Unread post by Simon99 »
You should be able to get the correct code from this very helpful forum:
http://forum.eserviceinfo.com/viewforum.php?f=8
Have to register first then post make, model, serial number etc. of radio. You will have to remove unit to read serial number etc.
If your radio isn't accepting any more codes leave it swicthed on with ignition for a few hours until it reads "code" again.
Hope they can help.
2002 C5 2.0 16v Estate
2001 C5 2.2hdi Hatchback
1998 Xantia 1.9td Estate
Simon99
Ooops... think you may have already tried this.
Simon99
If this is the stereo from the mark 2 xantia I believe I read somewhere it may be coded to the ecu only to work with original car. Don't know if this is correct, maybe thinking of C5 stereo.
citroenxm
Fallen Hero
x 70
Simon99,
NO thats not the case with Xantias
Thats only the case with C5's onwards... Xantia Mk.2's still use the older "Code in the Radio" system.. and with the case of S2 Xantia Clarion units in they need the Code chip Reading .... and cannot be decoded from the serieal, like Blaupunkts...
Paul
A very sad...
1994 XM 2.1 d auto
DickieG
x 38
If you cannot find a code for that radio don't throw it all away, certainly remove the facia if its OK as the displays are prone to going blank, it might come in handy.
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
x 8176
I don't suppose, by any chance, the serial number is also on a label stuck to the printed circuit board?
i3
Unread post by i3 »
?? i dont understand? what do you mean Jim? what is the printed circuit board?
