4-Bolt Crank Pulley Automatic Transmission
ellevie
Unread post by ellevie »
A topic that often comes up is how to remove the crankshaft pulley typically to change the timing belt. It is usually held on by a very tight large central bolt which requires the use of an air impact gun or using the starter motor trick to remove it.
The picture below shows the pulley on a 1999 Mitsubishi Galant 2L Automatic which is held on by four small bolts which are easy to remove. The four bolts attach the pulley to the timing sprocket behind the pulley. Interestingly the manual version of this model is held on by a large central bolt.
David
BX19TRS 120K E Reg 1992-2013
BX19TRS auto abs 96k F Reg
BX19TXD 150k K Reg
x 1060
Unread post by wheeler »
there are also quite a few PSA engines with this setup also, petrol and diesel.
ellevie
It would be nice if they were all attached this way. :D
David
BX19TXD 150k K Reg
JohnD
(Donor 2022)
x 72
Re: 4-Bolt Crank Pulley Automatic Transmission
Unread post by JohnD »
ellevie wrote:
which is held on by four small bolts which are easy to remove. ]
My diesel Saxo is one of them - the DW8 is another and Yes! it's a doddle to remove.
2010 C5 X7 VTR+Nav 160
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
