wich code reader I need to buy for c5 2.0 hdi 2002?
c5est
Unread post by c5est »
h2ocooler
Re: wich code reader I need to buy for c5 2.0 hdi 2002?
Unread post by h2ocooler »
c5est wrote:wich code reader I need to buy for c5 2.0 hdi 2002?
Depends on what you want to do with it...
Rob
2005 Renault Laguna II Sports Tourer Initiale 2.0 Turbo Auto Estate
2003 Citroen C8 2.2Hdi Exclusive Captains Chair
2007 Renault Megane 1.6VVT Cabriolet Coupe Dynamique
02 C5 2.2 Hdi Exclusive Auto Estate (my Dads) DE_FAPPED
c5est
Rob
If onist I think I have a imobiliser problem, I whant ceck it , because dealer asking 104 quid for diagnostic. it's will be much cheaper to buy one and I will have it for future, thanks
h2ocooler
LEXIA 3 will cost you from £139 on ebay but thats an import from hong kong, uk based supplier is about £200, then you need a laptop too.
Rob
jimleshed
Unread post by jimleshed »
I got one from Ebay for £139 and it works fine. Was a bit of a fight to install the software though!
Only works on XP, and as my two machines are vista and W7 i had to work around. Used a VM and all seems ok. been able to clear faults.
JLS
Jim Le Shed
Citroen C5 2.2 HDI Exclusive
Mazda RX8 231PS
Past history...
Mazda MX5
Renault Lagunas (3)
Peugeot 405, 205
Citroen CX's (5)
Citroen GS (lots of other Cars and Bikes too!!)
c5est
jimleshed wrote:I got one from Ebay for £139 and it works fine. Was a bit of a fight to install the software though!
JLS
have you think does it will sorted out my imobiliser problem?
boristhespie
x 4
Unread post by boristhespie »
Anyone lese with positive experience of £139 lexia from Hong Kong and who did you use?
Do they provide updates?
C'est pas possible!
jimleshed
Hi C5est, I really dont know. I only just got my Lexia3 and havent played with it much. Perhaps a more knowledgeable Lex user can answer that!
Boris - no, my lex does not get updates as far as I know, but again perhaps a more knowledgeable Lex user can answer that!
JLS
Jim Le Shed
Mazda RX8 231PS
Past history...
Mazda MX5
Renault Lagunas (3)
Peugeot 405, 205
Citroen CX's (5)
c5est
jimleshed wrote:Hi C5est, I really dont know. I only just got my Lexia3 and havent played with it much. Perhaps a more knowledgeable Lex user can answer that!
JLS
do you know can I get somethink expensiv, and what will take another cars to I need for my fiat stilo too, thanks for answers!
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
Yes I have one! Not 100 percent positive were exactly it came from, a UK importer I think but its a chineese one, and does everything I want for!!
VERY Pleased!
Used on an XP based laptop too, Dell D505..
Paul
A very sad...
1994 XM 2.1 d auto
x 1056
Unread post by wheeler »
JLS
Unless its just lost the key memory & they need reprograming then no it wont sort your immobiliser problem. It may however assist in finding what the fault is. Diagnostic tools are not magic things that you plug in & they tell you there is a broken wire under the passangers seat. You still need to use your head.
Reading the other post you made i doubt your fault is immobiliser related anyway. If the key warning light doesent flash constantly when you turn the ignition on then its unlikely an immobiliser problem.
c5est
JLS
when I was starting a car its show on display imobilaser problem, and it's wont start but didn't, and it's not displaying batery and oil on odo. but with cey I can open and lock the dors and it's not flashing imo light.
anothert think, I have fiat stilo wich flashing air bags faultly, and I whant get some diagnostick tool who can read fiat and citroen, fiat is petrol 2003 and citroen diesel 2002, thanks for replys!
c5est
citroenxm wrote:Yes I have one! Not 100 percent positive were exactly it came from, a UK importer I think but its a chineese one, and does everything I want for!!
VERY Pleased!
Paul
paul! can yuou please send some nummbers or somethink from your diagnostick tool. I can try to found somethink simular, thanks!
c5est
VERY Pleased!
Paul
can someone explain me why LEXIA is so good, or beter than all rest diagnostick tools, it's 2 times more expensive
x 5671
c5est wrote:
VERY Pleased!
Paul
Because it is Citroen-dedicated and can read the codes that other bee.. tools cannot reach.
