wich code reader I need to buy for c5 2.0 hdi 2002?
c5est
h2ocooler
Re: wich code reader I need to buy for c5 2.0 hdi 2002?
Depends on what you want to do with it...c5est wrote:wich code reader I need to buy for c5 2.0 hdi 2002?
Rob
2005 Renault Laguna II Sports Tourer Initiale 2.0 Turbo Auto Estate
2003 Citroen C8 2.2Hdi Exclusive Captains Chair
2007 Renault Megane 1.6VVT Cabriolet Coupe Dynamique
02 C5 2.2 Hdi Exclusive Auto Estate (my Dads) DE_FAPPED
c5est
If onist I think I have a imobiliser problem, I whant ceck it , because dealer asking 104 quid for diagnostic. it's will be much cheaper to buy one and I will have it for future, thanksh2ocooler wrote:Depends on what you want to do with it...c5est wrote:wich code reader I need to buy for c5 2.0 hdi 2002?
Rob
h2ocooler
LEXIA 3 will cost you from £139 on ebay but thats an import from hong kong, uk based supplier is about £200, then you need a laptop too.
Rob
Rob
jimleshed
I got one from Ebay for £139 and it works fine. Was a bit of a fight to install the software though!
Only works on XP, and as my two machines are vista and W7 i had to work around. Used a VM and all seems ok. been able to clear faults.
JLS
JLS
Jim Le Shed
Citroen C5 2.2 HDI Exclusive
Mazda RX8 231PS
Past history...
Mazda MX5
Renault Lagunas (3)
Peugeot 405, 205
Citroen CX's (5)
Citroen GS (lots of other Cars and Bikes too!!)
Mazda RX8 231PS
Past history...
Mazda MX5
Renault Lagunas (3)
Peugeot 405, 205
Citroen CX's (5)
c5est
have you think does it will sorted out my imobiliser problem?jimleshed wrote:I got one from Ebay for £139 and it works fine. Was a bit of a fight to install the software though!
JLS
boristhespie
- x 4
jimleshed
Hi C5est, I really dont know. I only just got my Lexia3 and havent played with it much. Perhaps a more knowledgeable Lex user can answer that!
Boris - no, my lex does not get updates as far as I know, but again perhaps a more knowledgeable Lex user can answer that!
JLS
JLS
Jim Le Shed
Mazda RX8 231PS
Past history...
Mazda MX5
Renault Lagunas (3)
Peugeot 405, 205
Citroen CX's (5)
Mazda RX8 231PS
Past history...
Mazda MX5
Renault Lagunas (3)
Peugeot 405, 205
Citroen CX's (5)
c5est
do you know can I get somethink expensiv, and what will take another cars to I need for my fiat stilo too, thanks for answers!jimleshed wrote:Hi C5est, I really dont know. I only just got my Lexia3 and havent played with it much. Perhaps a more knowledgeable Lex user can answer that!
JLS
citroenxm
- Fallen Hero
- x 70
Yes I have one! Not 100 percent positive were exactly it came from, a UK importer I think but its a chineese one, and does everything I want for!!
VERY Pleased!
Used on an XP based laptop too, Dell D505..
Paul
VERY Pleased!
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- x 1053
Unless its just lost the key memory & they need reprograming then no it wont sort your immobiliser problem. It may however assist in finding what the fault is. Diagnostic tools are not magic things that you plug in & they tell you there is a broken wire under the passangers seat. You still need to use your head.c5est wrote:have you think does it will sorted out my imobiliser problem?jimleshed wrote:I got one from Ebay for £139 and it works fine. Was a bit of a fight to install the software though!
JLS
Reading the other post you made i doubt your fault is immobiliser related anyway. If the key warning light doesent flash constantly when you turn the ignition on then its unlikely an immobiliser problem.
c5est
when I was starting a car its show on display imobilaser problem, and it's wont start but didn't, and it's not displaying batery and oil on odo. but with cey I can open and lock the dors and it's not flashing imo light.wheeler wrote:Unless its just lost the key memory & they need reprograming then no it wont sort your immobiliser problem. It may however assist in finding what the fault is. Diagnostic tools are not magic things that you plug in & they tell you there is a broken wire under the passangers seat. You still need to use your head.c5est wrote:have you think does it will sorted out my imobiliser problem?jimleshed wrote:I got one from Ebay for £139 and it works fine. Was a bit of a fight to install the software though!
JLS
anothert think, I have fiat stilo wich flashing air bags faultly, and I whant get some diagnostick tool who can read fiat and citroen, fiat is petrol 2003 and citroen diesel 2002, thanks for replys!
c5est
paul! can yuou please send some nummbers or somethink from your diagnostick tool. I can try to found somethink simular, thanks!citroenxm wrote:Yes I have one! Not 100 percent positive were exactly it came from, a UK importer I think but its a chineese one, and does everything I want for!!
VERY Pleased!
Paul
c5est
can someone explain me why LEXIA is so good, or beter than all rest diagnostick tools, it's 2 times more expensivec5est wrote:paul! can yuou please send some nummbers or somethink from your diagnostick tool. I can try to found somethink simular, thanks!citroenxm wrote:Yes I have one! Not 100 percent positive were exactly it came from, a UK importer I think but its a chineese one, and does everything I want for!!
VERY Pleased!
Paul
- x 5626
Because it is Citroen-dedicated and can read the codes that other bee.. tools cannot reach.c5est wrote:can someone explain me why LEXIA is so good, or beter than all rest diagnostick tools, it's 2 times more expensivec5est wrote:paul! can yuou please send some nummbers or somethink from your diagnostick tool. I can try to found somethink simular, thanks!citroenxm wrote:Yes I have one! Not 100 percent positive were exactly it came from, a UK importer I think but its a chineese one, and does everything I want for!!
VERY Pleased!
Paul
