Help wobbly dual mass flywheel (DMF)
almateus
Hi, i have a c5 2.2, i have just taken the clutch out and noticed some play in the dual mass flywheel, anybody now how much play is ok and should the flywheel wobble
almateus
Pleiades
There is meant to be some play, it should feel a bit like moving it on a spring, when they go wrong, they will normally lock up solid.
Having said that, if you are in that far, the best advice is to replace it, treat the whole thing as a 4 piece clutch, it just is not worth the hassle of having it fail just after doing the clutch.
Regards.
Martin.
Regards.
Martin.
Gammy leg
cachaciero
- x 9
Didn't I read somewhere that the way to go was fit a solid flywheel and that Valeo now produced a clutch assembly that was effectifly the clutch and DMF function in one unit?
Sure I read that somewhere.
cachaciero
cachaciero
2006 Toyota Prius T Spirit
2001 2.2 C5 Exclusive SE
1996 XM 2.1 TD Auto VSX
1987 CX 2.5 Gti Turbo II dead
1984 Ford Scorpio
1981 CX 2.4 Pallas Auto
Renault 21
1220 GS Club
Rover P6 2000TC
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
almateus
almateus
