Help wobbly dual mass flywheel (DMF)
almateus
Unread post by almateus »
Hi, i have a c5 2.2, i have just taken the clutch out and noticed some play in the dual mass flywheel, anybody now how much play is ok and should the flywheel wobble
almateus
Pleiades
Unread post by Pleiades »
There is meant to be some play, it should feel a bit like moving it on a spring, when they go wrong, they will normally lock up solid.
Having said that, if you are in that far, the best advice is to replace it, treat the whole thing as a 4 piece clutch, it just is not worth the hassle of having it fail just after doing the clutch.
Regards.
Martin.
Gammy leg
Unread post by Gammy leg »
Excuse my ignorance but what is the purpose of a dual mass flywheel? In what way do they differ from ye olde types?
Gammy :?
2000 Synergie 1.9Td
x 5675
Here's an animated description from YouTube.
It doesn't seem to start on its own, click the progress bar just ahead of the indicator to get it going.
cachaciero
x 9
Unread post by cachaciero »
Didn't I read somewhere that the way to go was fit a solid flywheel and that Valeo now produced a clutch assembly that was effectifly the clutch and DMF function in one unit?
Sure I read that somewhere.
cachaciero
2006 Toyota Prius T Spirit
2001 2.2 C5 Exclusive SE
1996 XM 2.1 TD Auto VSX
1987 CX 2.5 Gti Turbo II dead
1984 Ford Scorpio
1981 CX 2.4 Pallas Auto
Renault 21
1220 GS Club
Rover P6 2000TC
almateus
i think i will replace it as there is no tension at all when i turn it, it doesnt spring back and it also wobbles quite a lot.
thanks for your comments
almateus
almateus
hi, anybody now what size the bolt head is on the flywheel
almateus
