Does anyone know the make of turbo on the Xantia 2.0CT?
I think it might be a Garrett, but which specific one is it?
Also where can you get the C-clips for the actuator rod?
Turbo
Deanxm
- x 87
Hi
on the XM which has the same engine its a Garrett TB25,
The circlips should be able to be sourced at any harware shop.
D
D
XM Prestige PRV6 92
Mitsubishi L200 Trojan 14
ACTIVE8
- x 6
Yes I thought a C-clip from a check strap, or similar could be used, but as everything is made to a price, and you get what you pay for.Deanxm wrote:Hi
D
It left me wondering if the C-clip would drop off if, one tried a C-clip from a door check strap, as they don't need to endure much heat in the door area.
While the C-clip on the turbo has to endure a lot of heat, and I wouldn't want to have the C-clip drop off while driving.
ACTIVA
Deanxm
- x 87
Surely the real deal would be available from citroen for just a couple of quid, you have peice of mind then that you have the intended part for the job....
D
D
XM Prestige PRV6 92
KevMayer
The clip on the waste gate actuator isn't a 'C' clip it's actually an 'E' clip.
I had to change mine a while ago and bought a box full off ebay.
PM me with your address and I'll send you a couple.
Cheers, Kev
- x 8441
