Xantia 2.0 Hdi. Intermittent Stop and light on Temp Gauge
jcdel
Unread post by jcdel »
I'm relying on you guys again.The stop sign and red panel light intermittently flash on and off.(Temp Gauge).I have noticed that this sometimes happens on bends and roundabouts etc.All water levels are OK etc.Thanks for any help.
x 5674
Loose connection on the water level sensor I imagine.
Clogzz
x 40
Unread post by Clogzz »
With the temperature gauge light on, isn’t that our old mate the brown sensor ?
If the cooling fans are going at full speed when the lights flash, it’s usually caused by a loose brown sensor connector.
jcdel
Thanks guys I will check tomorrow.On reflection the fans have come on recently for no apparent reason.Still the middle of winter in east Yorkshire.
DickieG
Monaco's youngest playboy
x 38
Unread post by DickieG »
Take a look at this thread.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
Confirmed... I also had this headache with a W 2000 Xantia HDi 110bhp..
STOP and the Red Coolant light... I swapped sensors, and level sender.. however, as already said in that thread it turned out to be one of the Fan relays located between the Fans, behind the cover under the bonnet...
I also connected the Lexia to find it reporting a "Short Curcuit in Slow speed Fans"
After pulling relays out cleaning contacts etc, and re connecting it all up, Fans worked both speeds and the Light stopped flashing.
Paul
A very sad...
1994 XM 2.1 d auto
DickieG
x 38
The repair on my HDi is still good over a year later :D
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
