head tightening torques
geedee
Unread post by geedee »
Hi I'm replacing my head gasket on my Citroen Relay of the X Reg vintage, fitted with a 1.9 non turbo diesel XUD engine, can anybody tell me the correct head bolt tightening torque for the new stretch head bolts
Jeth
Unread post by Jeth »
First tighten all of them to 20nm
After that, 60nm
Finally 180 degrees
BX 16V -89 "lowrider" , Xantia HDi -99, Visa 14TRS -86, 2CV -71 ("daddy loaners" : Dyane -74, DS Super -72, C5 2.0HDi -07, 2CV Mixte -62, 2CV4 -72)
Old-Guy
x 24
Unread post by Old-Guy »
At the risk of stating the obvious...
It's absolutely vital to tighten head bolts progressively in the correct sequence (refer to this scanned copy of the BoL). Personally, for the extra few minutes work, I wind down bolts in sequence until they touch the head, then tighten (in sequence) in steps of 10nm until I reach the required final pre-load figure (60 nm), again in sequence, I then rotate the extra angle (180 degrees) to tension the bolts. You can buy special tools to do the angles 'accurately', but it's a pretty poor mechanic who can't judge an accurate 60,90, 120, or 180 degrees.
tonupteabag
Unread post by tonupteabag »
i was under the impression that the final angle tightening sequence was in two stages of 90 degrees :?
honda cb900 x3
"if i wanted my car to be mint i would have bought a polo"
