Berlingo problem
paul whalley
Berlingo problem
Unread post by paul whalley »
The light that tells me my hand brake is on keeps flashing/stays on while driving and the is brake fluid reservoir is on the full mark. any idea's?
Paul
Peugeot Boxer 2.0 HDI 53
Citroen Berlingo 1.9d 1998
Saab 93 1.9 (150) tid 57
peugeot boxer 2.0 HDI 54
x 5579
Brake pads at their wear limit? Check the pad thickness. Only works on the front brakes as far as I'm aware.
Otherwise the handbrake switch faulty or the fluid level sensor, you should be able to check these by disconnecting them.
paul whalley
myglaren wrote:Brake pads at their wear limit? Check the pad thickness. Only works on the front brakes as far as I'm aware.
Pads are fine! will check the handbrake switch and fluid sensor
Paul
x 1044
Unread post by wheeler »
The brake fluid level sensors are a relativley common failure, you have to change the whole reservoir as the sensor is not a seperate part.
paul whalley
wheeler wrote:The brake fluid level sensors are a relativley common failure, you have to change the whole reservoir as the sensor is not a seperate part.
yes this seams to be the problem. I have unplugged it and the light is no longer flashing thanks!
any one got any idea how much a new one will cost :?:
Paul
