Berlingo problem
paul whalley
Berlingo problem
The light that tells me my hand brake is on keeps flashing/stays on while driving and the is brake fluid reservoir is on the full mark. any idea's?
Paul
Peugeot Boxer 2.0 HDI 53
Citroen Berlingo 1.9d 1998
Saab 93 1.9 (150) tid 57
peugeot boxer 2.0 HDI 54
- x 5671
paul whalley
Pads are fine! will check the handbrake switch and fluid sensormyglaren wrote:Brake pads at their wear limit? Check the pad thickness. Only works on the front brakes as far as I'm aware.
Otherwise the handbrake switch faulty or the fluid level sensor, you should be able to check these by disconnecting them.
Paul
- x 1052
paul whalley
yes this seams to be the problem. I have unplugged it and the light is no longer flashing thanks!wheeler wrote:The brake fluid level sensors are a relativley common failure, you have to change the whole reservoir as the sensor is not a seperate part.
any one got any idea how much a new one will cost
Paul
