Xantia 90Bhp HDI Engine Management Warning Light On
wrinklet1
Unread post by wrinklet1 »
Hi all. The Engine management light has come on, on my Xantia MkII HDI 90 Bhp Sx. I had a in line chip fitted and it stopped working, the car would idle ok. I took the chip out and the car runs ok. But the engine warning light is light up all the time. The car runs 100% ok.
Now could I have disturbed something or could it be that after a certain length of time the light will go out?????
Paul
1xAmi,3xGS,2xBx,2xAX,2xSaxo,1xXantia mk I,2xXantia MkII,1xC1,2xC2,
x 5674
If it is nothing serious it should go out after three restarts without a recurrence of the original problem.
Otherwise it will need investigating.
wrinklet1
it has been more than 3 restarts,
DickieG
Monaco's youngest playboy
x 38
Unread post by DickieG »
Faults are logged in the ECU memory for 40 starts.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
wrinklet1
Ahh, so after about 40 starts the light ay go out then??????
wrinklet1
Hi again, well I have given the car about 50 starts and the engine warning light is still on!!!!!! Could a sensor have been disconected? If so, would the car still run ok? Because the car is running as normal!!!!!!!
seany87
Unread post by seany87 »
I got a friend to check mine as it wouldnt go out and drove fine, it turned out to be the throttle position sensor - cleared it and its not come back on
wrinklet1
Hi, How did you clear the throttle sensor????
DHallworth
x 167
Unread post by DHallworth »
There's an option on the Lexia to clear the fault codes.
A lot of the time once the codes have been cleared they don't come back unless the sensor is actually faulty.
It could of been a sensor that gave an out of range reading that triggered your light.
David.
'98 Xantia Activa V6 :-D
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
