Xantia TD cold start
firstrebel
Unread post by firstrebel »
Last year I fitted new glo-plugs to my 1997 1.9 Xantia SX TD, with DickieG's help, and it started perfectly every time. Over the past few months it splutters on cold start with lots of smoke from the tail pipe.
If I turn on the ignition, then off again when the glo-plug light goes off, then back on, it starts better. It seems to want more heat on the glo-plugs.
Why is this?
Bob
Robert Isaac
1997 Xantia 1.9TD SX Estate. 152000 miles
1995 Volvo 855 T5 Auto - Chipped. 186000 miles
spider
x 77
Unread post by spider »
It could be air ingress, although if it starts better with two "glows" , I'd say you have a glowplug down (or weak)
It could be the timer / relay but that's less likely.
Andy.
HDI
x 7
Unread post by HDI »
I would agree , thats a typical symptom of a dead or dying glow plug.
Which make of plug did you use ?
Now using '00 Xantia LX HDI, pov spec :(
My past Citroens :-
'00 Xantia SX HDI, now dead due to accident :(
'99 Xantia HDI 110 Exclusive, RIP :(
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
'79 CX2400 Pallas (scrapped :( )
& a couple of Peugeots !
spider
x 77
Slightly off topic (sorry) but I have seen failing plugs where they glow in the middle rather than the end...
That kind of problem is not really detectable until you bench (well, vice) test them.
Andy.
x 1481
At 150k, if the glowplugs check out OK, it's probably worth checking the valve clearances - the exhausts tend to close up at higher mileage, and stay open a fraction when cold, which makes them rather difficult to start...
HDI
x 7
spider wrote:Slightly off topic (sorry) but I have seen failing plugs where they glow in the middle rather than the end...
Glad I'm not the only one that tests old glowplugs :wink: Another fault I've found is that defective ones glow less hot on reduced supply voltage than new ones.
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
Martin Beevers
Unread post by Martin Beevers »
I have this problem with my car. Even with new glow plugs fitted.
I find that if I count to 10 after the glow plug light goes out, then start her up, she starts on the first turn with no smoke. :D
95 Xantia 1.9TD SX - Now sold
spider
x 77
Martin Beevers wrote:I find that if I count to 10 after the glow plug light goes out, then start her up, she starts on the first turn with no smoke. :D
They do remain energized for a few seconds after the light goes out, sometimes you can hear the relay click off about 5 seconds after the warning light goes out (on my 205, I can see the stop light brighten slightly and hear the relay switch off so I know they have gone "off") , but the staying on for a few seconds after the light (until you attempt to start) is quite normal. I'm skipping post heating stuff here as that's off topic. :)
Andy.
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
RichardW wrote:At 150k, if the glowplugs check out OK, it's probably worth checking the valve clearances - the exhausts tend to close up at higher mileage, and stay open a fraction when cold, which makes them rather difficult to start...
Really? Whats high milage ? My Xantia TD at 225k starts perfectly, Ive never touched the valve clearences, and always changed the oil at 5k intervals..
Ive not come across closed clearences, what causes this? I find something with shims very hard to close up, Yes rocker fingers could close up, but bucket and shims? :-k
Paul
A very sad...
1994 XM 2.1 d auto
jonathan_dyane
Unread post by jonathan_dyane »
They do close up, but it's due to overheating rather than mileage.
Jonathan
1986 Mercedes Benz 190D 2.5
1979 GS 1220 Club Estate awaiting more welding
1952 David Brown 30D awaiting new liners
x 8309
citroenxm wrote: Ive not come across closed clearences, what causes this?
This is a very common problem on the NA 1.7 XUD but is rare (ish) on the 1.9TD.
The XUD has a quirk where the valve clearances are tigthtest when the engine is stone-cold. The open as the engine warms. Just a tad of heat is often enough.
On the 1.7 XUD it is suspected that the constant valve operation hammers the valve seat inserts further into the head over time.
If a 1.9TD is a reluctant cold starter and all the usual suspects are innocent, a check of the valve clearances is worthwhile. It's a fun job resettingt hem though but I do have an Excel spreadsheet to help with that task...
spider
x 77
CitroJim wrote:This is a very common problem on the NA 1.7 XUD but is rare (ish) on the 1.9TD.
Jim, do you know how common (or not, as the case may be) with this on a 1.7XUDT ?
Mine seem OK (at about 179K now) , I've never had to set them, thankfully as its not a very nice job (not done one, seen it done years ago)
I know there's always exceptions and the odd 1.9XUDT will have this, just curious if its only the most common on the 1.7 N/A's really :)
Andy.
DickieG
Monaco's youngest playboy
x 38
Unread post by DickieG »
Both of my C15D's "suffered" from it and ran a lot smoother and more powerful after I reset the valve clearances.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
x 8309
A dead giveaway that valve clearances are tight is copious white smoke when trying to start. White smoke is in fact unburned fuel going straight out of the exhaust...
It is, I believe, very common on 1.7 NA XUDs but I don't believe it is so common on the 1.7 Turbo.
Although the heads are substantially the same, the valve timing is wilder on on an NA and the compression ratio is much higher. Both might have an effect over time...
jonnydrumm1967
Unread post by jonnydrumm1967 »
I'm looking to purchase a C15 with the 1868cc diesel engine.It's apparently suffering from the poor cold start syndrome.It's had the usual stuff,new battery,starter and glowplugs but still struggles to start.Once it's got going it will then start all day no probs.
Does this engine suffer from valve clearance troubles too? or could it maybe be a relay to the plugs not working?
Sorry I've no idea of the mileage.
2000 XANTIA HDi 110 SX Est
1992 205 GTI TD
1996 DISCOVERY TDI
2001 XANTIA HDi LX
1991 205 D Turbo
