Xantia TD cold start
firstrebel
Last year I fitted new glo-plugs to my 1997 1.9 Xantia SX TD, with DickieG's help, and it started perfectly every time. Over the past few months it splutters on cold start with lots of smoke from the tail pipe.
If I turn on the ignition, then off again when the glo-plug light goes off, then back on, it starts better. It seems to want more heat on the glo-plugs.
Why is this?
Bob
Why is this?
Bob
Robert Isaac
1997 Xantia 1.9TD SX Estate. 152000 miles
1995 Volvo 855 T5 Auto - Chipped. 186000 miles
spider
- x 77
HDI
- x 7
I would agree , thats a typical symptom of a dead or dying glow plug.
Which make of plug did you use ?
Now using '00 Xantia LX HDI, pov spec
My past Citroens :-
'00 Xantia SX HDI, now dead due to accident
'99 Xantia HDI 110 Exclusive, RIP
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
'79 CX2400 Pallas (scrapped
& a couple of Peugeots !
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
spider
- x 77
Slightly off topic (sorry) but I have seen failing plugs where they glow in the middle rather than the end...
That kind of problem is not really detectable until you bench (well, vice) test them.
Andy.
- x 1480
HDI
- x 7
Glad I'm not the only one that tests old glowplugsspider wrote:Slightly off topic (sorry) but I have seen failing plugs where they glow in the middle rather than the end...
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
Martin Beevers
spider
- x 77
They do remain energized for a few seconds after the light goes out, sometimes you can hear the relay click off about 5 seconds after the warning light goes out (on my 205, I can see the stop light brighten slightly and hear the relay switch off so I know they have gone "off") , but the staying on for a few seconds after the light (until you attempt to start) is quite normal. I'm skipping post heating stuff here as that's off topic.Martin Beevers wrote:I find that if I count to 10 after the glow plug light goes out, then start her up, she starts on the first turn with no smoke.
Andy.
citroenxm
- Fallen Hero
- x 70
Really? Whats high milage ? My Xantia TD at 225k starts perfectly, Ive never touched the valve clearences, and always changed the oil at 5k intervals..RichardW wrote:At 150k, if the glowplugs check out OK, it's probably worth checking the valve clearances - the exhausts tend to close up at higher mileage, and stay open a fraction when cold, which makes them rather difficult to start...
Ive not come across closed clearences, what causes this? I find something with shims very hard to close up, Yes rocker fingers could close up, but bucket and shims?
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
jonathan_dyane
- x 8287
This is a very common problem on the NA 1.7 XUD but is rare (ish) on the 1.9TD.citroenxm wrote: Ive not come across closed clearences, what causes this?
The XUD has a quirk where the valve clearances are tigthtest when the engine is stone-cold. The open as the engine warms. Just a tad of heat is often enough.
On the 1.7 XUD it is suspected that the constant valve operation hammers the valve seat inserts further into the head over time.
If a 1.9TD is a reluctant cold starter and all the usual suspects are innocent, a check of the valve clearances is worthwhile. It's a fun job resettingt hem though but I do have an Excel spreadsheet to help with that task...
spider
- x 77
Jim, do you know how common (or not, as the case may be) with this on a 1.7XUDT ?CitroJim wrote:This is a very common problem on the NA 1.7 XUD but is rare (ish) on the 1.9TD.
Mine seem OK (at about 179K now) , I've never had to set them, thankfully as its not a very nice job (not done one, seen it done years ago)
I know there's always exceptions and the odd 1.9XUDT will have this, just curious if its only the most common on the 1.7 N/A's really
Andy.
DickieG
- Monaco's youngest playboy
- x 38
Both of my C15D's "suffered" from it and ran a lot smoother and more powerful after I reset the valve clearances.spider wrote:Jim, do you know how common (or not, as the case may be) with this on a 1.7XUDT ?CitroJim wrote:This is a very common problem on the NA 1.7 XUD but is rare (ish) on the 1.9TD.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
- x 8287
A dead giveaway that valve clearances are tight is copious white smoke when trying to start. White smoke is in fact unburned fuel going straight out of the exhaust...
It is, I believe, very common on 1.7 NA XUDs but I don't believe it is so common on the 1.7 Turbo.
Although the heads are substantially the same, the valve timing is wilder on on an NA and the compression ratio is much higher. Both might have an effect over time...
jonnydrumm1967
I'm looking to purchase a C15 with the 1868cc diesel engine.It's apparently suffering from the poor cold start syndrome.It's had the usual stuff,new battery,starter and glowplugs but still struggles to start.Once it's got going it will then start all day no probs.
Does this engine suffer from valve clearance troubles too? or could it maybe be a relay to the plugs not working?
Sorry I've no idea of the mileage.
2000 XANTIA HDi 110 SX Est
1992 205 GTI TD
1996 DISCOVERY TDI
2001 XANTIA HDi LX
1991 205 D Turbo
1992 205 GTI TD
1996 DISCOVERY TDI
2001 XANTIA HDi LX
1991 205 D Turbo
