Folks, I'm stuck. Or rather, the pollen filter appears to be. While I had the footwell carpet out to check something else, I thought I might remove the pollen filter and check the condition.
Can't get it to shift. Either that or I am looking at something else entirely. Haynes manual refers to three securing screws, but I can't see any screws, and the filter (or what I think is the filter) will not be pulled out.
It does shift laterally a couple of mm either way.
Any suggestions?
Cheers
Ainslie.
Pollen Filter, W (2000) Xantia Forte 1.8
DickieG
- Monaco's youngest playboy
- x 33
- x 1459
Gingerposer
- x 6
Sid_the_Squid
I believe the covers slight to the right, i.e. towards the driver, to come off.
If your pollen filter cover is a slide off type take note of its shape this will clue you in on the orientation of the filter element on refitting, don't be tempted to put the tapered end in at the top, I believe the tapered end faces towards the passenger side door. The pollen filter element is designed to only fit one way, however I have personally removed 3 filters from 3 different Xantias where the previous changer had somehow managed to force the filter elements in incorrectly, if you get the orientation correct, the element will slide in easily, and the slide cover will close easily.
This may apply to all pollen filters, I don't know I've only ever seen the type with sliding covers.
Gone to the dark side.
Past Citroens
'99 Xantia HDi Exclusive
'99 Xantia 3.0 V6 Exclusive (Green Goblin)
'02 C5 Hdi 110 LX Estate
'98 Xantia 1.8 sx auto with LPG
'00 Xantia Hdi (110) forte
'97 Xantia 1.9D sx
'93 Xantia 1.9D lx (my first) R.I.P
Past Citroens
'97 Xantia 1.9D sx
Clogzz
- x 40
Sid_the_Squid
Not all mk1's Cloggz I know of a late mk1 very close to me with a slide type.
Past Citroens
'97 Xantia 1.9D sx
Past Citroens
'97 Xantia 1.9D sx
Clogzz
- x 40
addo
- Sara Watson's Stalker
- x 95
Gingerposer
- x 6
