Pollen Filter, W (2000) Xantia Forte 1.8
Gingerposer
x 6
Unread post by Gingerposer »
Folks, I'm stuck. Or rather, the pollen filter appears to be. While I had the footwell carpet out to check something else, I thought I might remove the pollen filter and check the condition.
Can't get it to shift. Either that or I am looking at something else entirely. Haynes manual refers to three securing screws, but I can't see any screws, and the filter (or what I think is the filter) will not be pulled out.
It does shift laterally a couple of mm either way.
Any suggestions?
Cheers
Ainslie.
DickieG
Monaco's youngest playboy
x 33
Unread post by DickieG »
Some pollen filter covers don't use screws to secure them, they simply slide off.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
x 1459
Unread post by xantia_v6 »
DickieG wrote:Some pollen filter covers don't use screws to secure them, they simply slide off.
To be slightly more precise, they slide along the long axis of the cover, for about 6mm then pull down. Sorry, I can't remember which direction is off... but they can be quite tight.
Gingerposer
x 6
smashing, I'll give that a try this evening and report progress.
ainslie
Sid_the_Squid
Unread post by Sid_the_Squid »
I believe the covers slight to the right, i.e. towards the driver, to come off.
If your pollen filter cover is a slide off type take note of its shape this will clue you in on the orientation of the filter element on refitting, don't be tempted to put the tapered end in at the top, I believe the tapered end faces towards the passenger side door. The pollen filter element is designed to only fit one way, however I have personally removed 3 filters from 3 different Xantias where the previous changer had somehow managed to force the filter elements in incorrectly, if you get the orientation correct, the element will slide in easily, and the slide cover will close easily.
This may apply to all pollen filters, I don't know I've only ever seen the type with sliding covers.
Gone to the dark side.
Past Citroens
'99 Xantia HDi Exclusive
'99 Xantia 3.0 V6 Exclusive (Green Goblin)
'02 C5 Hdi 110 LX Estate
'98 Xantia 1.8 sx auto with LPG
'00 Xantia Hdi (110) forte
'97 Xantia 1.9D sx
'93 Xantia 1.9D lx (my first) R.I.P
Clogzz
x 40
Unread post by Clogzz »
The screwed cover is on the Mk I.
Picture of filter and sliding cover from the Mk II:
Sid_the_Squid
Not all mk1's Cloggz I know of a late mk1 very close to me with a slide type.
Past Citroens
'97 Xantia 1.9D sx
Clogzz
x 40
I easily believe that.
That’s what Citroën calls ‘constant evolution’, with the transition to the Mk II being done ‘piecemeal’.
addo
Sara Watson's Stalker
x 95
Unread post by addo »
There is an arrow embossed upon thine cover, to indicate which direction of slidage releases it.
Gingerposer
x 6
Forsooth! I had not considered ye slidage, I had embarked upon prising and wrenchage! I see I must adapt my tactic somewhat.
