On Xantia hatch I have accumulation of water which spills back into channels and then into boot area when hatch door is lifted full height. I have cleaned the drain holes with compessed air and a small piece of welding wire.....no change.
Could my tailgate membrane be the cause?
annoying tailgate water.
lexi
- x 133
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
VertVega
- x 13
Re: annoying tailgate water.
If that's an estate model, yes.lexi wrote:... Could my tailgate membrane be the cause?
You should check the adhesive/sealant at the lower part of the membrane,
especially around the curves nearby the lock mechanism.
Check also if there's water in the rear passenger footwell.
Tip: I have renewed membrane adhesive by 3M auto glass sealant tape.
Here's a link to 3M Ribbon Sealers
Citroenmad
- x 110
No, think this is a common problem on Xantia hatchbacks. If its been parked in the rain and you go to open the boot, some might spill inside. I remember us sending ours back to the Citroen dealer when it was new to have it looked at.
C5s almost have the same problem, but usually it falls into the chanels at the side of the opening, but sometimes it goes in the boot. Though not on the back seats like our old Xantia used to
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
Martin Beevers
lexi
- x 133
Thanks guys. It`s the V6 hatch. I have done the membrane on two estates previously.
The water seems to channel into a very tight bottleneck. which clogs with dirt. However even after cleaning there is still water being held. In the design then......which is poor.
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Clogzz
- x 40
Also always had water dripping into the boot with the lid up.
All the water from the channel is dumped onto the tail light cluster.
If the cluster seal leaks, water gets into the boot through the opening for the wires, with water sloshing around inside the cluster.
