C5 brake fluid change
GB
Unread post by GB »
Apart from a brake bleeding kit are there any other "unusual" tools required for C5 brake fluid change?
Someone on this forum mentioned that Lexia is required for a proper C5 brake fluid change - is this the case?
Cheers,
GB
05 C5 VTR 2.0 HDI
115k
Clogzz
x 40
Unread post by Clogzz »
Not for brake fluid change, as it’s an ordinary system with undyed DOT 4 fluid.
The suspension LDS fluid change is supposed to be done with a Lexia to open an electro valve, but even that only releases very little more fluid.
x 5675
I'm reasonably certain that a Lexia is supposed to be used to open a valve in the ABS when pushing the pistons back into the calipers, otherwise damage can be done to the ABS.
Not required for a straight brake bleed AFAIK.
uncle buck
x 10
Unread post by uncle buck »
myglaren wrote:I'm reasonably certain that a Lexia is supposed to be used to open a valve in the ABS when pushing the pistons back into the calipers, otherwise damage can be done to the ABS.
When pushing the pistons back on any car it's good idea to clamp the flexi hose & opening the bleed nipple so you don't push the fluid back through the system :wink:
Cheers.
2006 C4 1.6 HDi 16V (92) non FAP
2001 Xsara II 1.4 LX
2001 Renault Laguna II 1.9dCi Sport Tourer
Citroenmad
x 110
Unread post by Citroenmad »
So in order to change brake pads you need a lexia? Surely not?
Ive done the back brakes on the SX C5 without any problems.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
x 1943
Unread post by Paul-R »
Citroenmad wrote:So in order to change brake pads you need a lexia? Surely not?
As have I on my C5.
As I understand it if the ABS gets confused through unequal amounts of brake fluid passing throuhj then you need a Lexia to reset it. So, if you're careful, you don't need a Lexia.
x 1056
Unread post by wheeler »
You deffo dont need a Lexia to change C5 brake pads. You do need the Lexia however to purge the ABS unit if it has been removed or a new unit fitted.
Citroenmad
x 110
Thats good to know, i didnt think it would have been somehting needed to change brake pads, but you never know on modern cars! :lol:
I had my LDS fluid changed recently, i know lexia is needed for that, bleeding the suspension system.
03 Seat Arosa 1.0S
x 1056
Citroenmad wrote: I had my LDS fluid changed recently, i know lexia is needed for that, bleeding the suspension system.
You don't need a lexia for that either & you dont need the Lexia to de-pressureise the system.
Citroenmad
x 110
According to my local citroen indy, lexia is needs to depressurise the system. As when low is selected in a C5 it doesnt go into fully low. Though i can only go on what ive been told.
03 Seat Arosa 1.0S
cachaciero
x 9
Unread post by cachaciero »
Citroenmad wrote:According to my local citroen indy, lexia is needs to depressurise the system. As when low is selected in a C5 it doesnt go into fully low. Though i can only go on what ive been told.
That's true, with a Lexia you can overide the system and open the the valves to allow the system to depressurise fully. However without a Lexia you can still de-pressurise the system mechanically, there are a couple of bleed valves for this purpose.
cachaciero
