Apart from a brake bleeding kit are there any other "unusual" tools required for C5 brake fluid change?
Someone on this forum mentioned that Lexia is required for a proper C5 brake fluid change - is this the case?
Cheers,
GB
Clogzz
- x 40
- x 5674
uncle buck
- x 10
When pushing the pistons back on any car it's good idea to clamp the flexi hose & opening the bleed nipple so you don't push the fluid back through the systemmyglaren wrote:I'm reasonably certain that a Lexia is supposed to be used to open a valve in the ABS when pushing the pistons back into the calipers, otherwise damage can be done to the ABS.
Not required for a straight brake bleed AFAIK.
Cheers.
2001 Xsara II 1.4 LX
Citroenmad
- x 110
So in order to change brake pads you need a lexia? Surely not?
Ive done the back brakes on the SX C5 without any problems.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
- x 1941
As have I on my C5.Citroenmad wrote:So in order to change brake pads you need a lexia? Surely not?
As I understand it if the ABS gets confused through unequal amounts of brake fluid passing throuhj then you need a Lexia to reset it. So, if you're careful, you don't need a Lexia.
- x 1056
Citroenmad
- x 110
Thats good to know, i didnt think it would have been somehting needed to change brake pads, but you never know on modern cars!
I had my LDS fluid changed recently, i know lexia is needed for that, bleeding the suspension system.
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
- x 1056
Citroenmad
- x 110
According to my local citroen indy, lexia is needs to depressurise the system. As when low is selected in a C5 it doesnt go into fully low. Though i can only go on what ive been told.
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
cachaciero
- x 9
That's true, with a Lexia you can overide the system and open the the valves to allow the system to depressurise fully. However without a Lexia you can still de-pressurise the system mechanically, there are a couple of bleed valves for this purpose.Citroenmad wrote:According to my local citroen indy, lexia is needs to depressurise the system. As when low is selected in a C5 it doesnt go into fully low. Though i can only go on what ive been told.
cachaciero
