Our Xantia V6 developed a really bad misfire today so I plugged it into the Lexia.
Turns out the misfire has cleared itself. Think it was water in the petrol as it was filled yesterday.
However it did come up with the below faults from the ECU's.....
Anybody got any suggestions?
Gearbox ECU
Permanent Fault - Stop Lamp Switch
Suspension ECU
Intermittent Fault - Steering Wheel Sensor
Intermittent Fault - Fuel System
Intermittent Fault - Front Electrovalve
Intermittent Fault - Rear Electrovalve
Intermittent Fault - Auto Diagnostic Line
Dead Locks ECU
Intermittent Fault - Low Voltage Detection
Injection ECU
Intermittent Fault - Water Temperature sensor coherence
Coded Anti Theft Device ECU
Fault - Engine Control Unit Connection
Any suggestions that you guys can suggest would be welcomed!
I wondered if the suspension ECU could be caused by buggered mosfets.
David.
Xantia V6 Fault Codes
DHallworth
- x 167
'98 Xantia Activa V6
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
Sl4yer
DickieG
- Monaco's youngest playboy
- x 33
