Xantia V6 Fault Codes
DHallworth
x 163
Unread post by DHallworth »
Our Xantia V6 developed a really bad misfire today so I plugged it into the Lexia.
Turns out the misfire has cleared itself. Think it was water in the petrol as it was filled yesterday.
However it did come up with the below faults from the ECU's.....
Anybody got any suggestions?
Gearbox ECU
Permanent Fault - Stop Lamp Switch
Suspension ECU
Intermittent Fault - Steering Wheel Sensor
Intermittent Fault - Fuel System
Intermittent Fault - Front Electrovalve
Intermittent Fault - Rear Electrovalve
Intermittent Fault - Auto Diagnostic Line
Dead Locks ECU
Intermittent Fault - Low Voltage Detection
Injection ECU
Intermittent Fault - Water Temperature sensor coherence
Coded Anti Theft Device ECU
Fault - Engine Control Unit Connection
Any suggestions that you guys can suggest would be welcomed!
I wondered if the suspension ECU could be caused by buggered mosfets.
David.
'98 Xantia Activa V6 :-D
'00 XM V6 Exclusive
'09 C5 2.7 HDi Exclusive
‘10 C5 3.0 HDi Exclusive
'12 C6 3.0 HDi Exclusive
'15 C4 BlueHDi Feel
Sl4yer
Unread post by Sl4yer »
As a rough guess for that lot, are your battery and alternator OK?
Now Citroenless for the first time in 20 years
2008 Mazda RX-8 231
2007 Honda CR-V Auto
DickieG
Monaco's youngest playboy
x 38
Unread post by DickieG »
The Gearbox one, you must press the brake pedal when the codes are read, the suspension and other faults, not unusual clear them and re-read after a week or so.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
