hi all i have a problem with a pug 106 diesel cutting out up hills.
it is a 1.5 disel 1998 reg non turbo.
its havin trouble starting some mornings and cuts out when you go up hills nearly all the time u drive got 79 tho on clock clean car dont wanna get rid been good to me any help would be aprecitated thanx....
Dommo
- x 20
- x 1240
marcsm8
- x 1240
Ah, well that's the most obvious thing ruled out. The next most likely thing is air getting into the fuel supply, check that the filter is screwed together tight, check all the pipe work from the pump back as far as you can go. If it has a Bosch pump check the leak off pipe connections. if that doesnt work, check the filter in the fuel tank.
marcsm8
- x 1240
marcsm8
- x 1240
marcsm8
- x 1240
marcsm8
- x 1240
