106 diesel cutting out
marcsm8
Unread post by marcsm8 »
hi all i have a problem with a pug 106 diesel cutting out up hills.
it is a 1.5 disel 1998 reg non turbo.
its havin trouble starting some mornings and cuts out when you go up hills nearly all the time u drive got 79 tho on clock clean car dont wanna get rid been good to me any help would be aprecitated thanx....
Dommo
x 20
Unread post by Dommo »
Have you ever changed the fuel filter?
x 1238
Unread post by Peter.N. »
Agree - fuel filter most likely
marcsm8
yes the fuel filter was changed on a service at a garge
x 1238
Ah, well that's the most obvious thing ruled out. The next most likely thing is air getting into the fuel supply, check that the filter is screwed together tight, check all the pipe work from the pump back as far as you can go. If it has a Bosch pump check the leak off pipe connections. if that doesnt work, check the filter in the fuel tank.
marcsm8
thanx for post gonna change fuel filter myself first then check everythnig from then it has got the bosch fuel pump there has been some air in tank when u open the filler cap hear it gurggling in tank does that help??...
x 1238
Well, the next thing I was going to suggest was a blocked fuel tank vent, do you get a 'whoosh' when you undo the cap?
marcsm8
yes it does sometimes if the cap has been on a while i also noticed the pipe after the filter which is clear. has bubbles flooating through on a constant basis.
x 1238
You are ahead of me :D I would have suggested that you fit a clear section of fuel line. Pump the primer while the engine is running and see if the bubbles stop, if they do, air is getting in after the primer, if not its before.
marcsm8
Changed fuel filter today still no joy still also gettin bubbles. priming the pump with engine running gets rid of bubbles but they come back. as i pump though with enghine not on i ear a slite whistling coming from n.o1 injector might be my next step.
x 1238
Do you have a bulb type primer or a pump on the filter? If its the latter I would suggest that the diaphragm is leaking.
marcsm8
its the bulb type pump its by the bulk head battery side not on pump...
x 1238
If pumping stops the bubbles the leak must be between the primer and the pump, even the primer and your section of clear pipe, check all the connections carefully.
