99 Berlingo multispace - a couple of problems
paul in normandy
Just acquired a 1999 Berlingo multispace, one of the 3 door + hatchback type things (what were they thinking of?) which has got a couple of problems. The dash lights don't work - I tried the remedy mentioned here, holding the rh button in but that did not work. It seems unlikely that all the bulbs are gone - has it got a seperate fuse, if so which one. I also cannot work out how to get at the sidelight to replace a bulb, thought I would consult someone knowledgeable before being too brutal with it.
The car came without an owners handbook or a Haynes manual.
pk7478
paul in normandy
Old-Guy
- x 24
Answer: The wiring harness (and position of some fuses) can often be very different between engine variants.paul in normandy wrote: What's the engine type got to do with the fact that the dashboard illumination doesn't work or how you remove the sidelights?
paul in normandy
pk7478
paul in normandy
Looked everywhere for a plate like that, there does not appear to be one, there is an ally plate with the chassis number on it under the bonnet - but fortunately all the numbers are on the CG - and the 'type' is MCT5104CX432.
Must buy a Haynes manual methinks, especially as the R4 has succumbed to the tinworm and is no longer a goer.
DickieG
- Monaco's youngest playboy
- x 33
The age of your Berlingo is right at the point where a painted RP number under the bonnet changed over to the sticker above which is normally located on the drivers door 'A' pillar close to the hinging point. If you don't have the sticker have a look under the bonnet on the offside for a four digit number.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
pk7478
The best way is to input VIN here: http://service.citroen.com and
and tell us OPR or RPO or DAM(for ancient cars).
pk7478
pk7478
pk7478
Haynes book is for dummies. Do not read itpaul in normandy wrote:Looked everywhere for a plate like that, there does not appear to be one, there is an ally plate with the chassis number on it under the bonnet - but fortunately all the numbers are on the CG - and the 'type' is MCT5104CX432.
paul in normandy
pk7478
paul in normandy
